Kyosho v-one rrr
#7216
Originally Posted by rayjay
Hi all... I have recently bought a rrr 2nd hand. The car is going well however i find on our track that it doesnt grip really well. It tends to slide out going around corners a fair bit. I would have to say our track is fairly low grip as it is set up in a carparking lot. Im just woundering what set up advice you could give me. I also run a front one way , and i also use grippy tyres all round. 26 35 front & 30 35 rear.
Cheers
Ray
Cheers
Ray
#7217
Originally Posted by miker2209
Wasap Robert? So are you getting ready for your 720? That's the word in the Oakland Park area...... King of Go Racing King going 720!!!
Later
Later
#7218
Define "those people"
Paolo
Paolo
#7219
Originally Posted by robert maestrey
Yes as a matter of fact I will be going to a 720 as soon as those people (thats the word) gives me one..
#7220
Cheers
Ray
Cheers
Ray
#7221
How do you guys like the Kyosho tires? How do they handle and how does the wheel hold up?
#7222
Cheers
Ray
Cheers
Ray
start with 10000....
use stock droop 0 front 4 rear
track width 200 rear 199 front
toe in rear start at 3 degrees
front sway bar soft(horizontal)
rear sway bar soft like 1.8 or softer
600 wt shock oil....black springs front -rear
camber 4 rear 2.5 front
rollcenters lowered front and rear
shock positions laydown
hope this helps
this is just a rough setup dont hold me to it
front diff might work if the track is real slippery.....
#7223
my car has a lot of play in the upper front sus. arms, one side has like 1mm of play and the other side has between 2 and 3mm of play, measured the bulkheads where the arms go and one side is bigger than the the other, anybody had this problem before? is it suposed to have any play (wich i doubt it) or do i have bad bulkheads?
#7224
Were you in a crash at all or has it always been like this?
#7225
Originally Posted by rmdhawaii
Make sure that when you tighten everything down, your car is sitting on a setup board. If you want to reduce the play, you can use the Kyosho 3mm shim set (Kyosho 96641 3x5 Sim Set - 0.1mm, 0.2mm, 0.3mm ; 10 each) to clean things up a bit. There has been some discussion if there should be any play at all. Some say that there should be no play at all - some say there should be some. I use shims and when I reassembled my car recently, I did have maybe 0.1-0.2mm of play.
#7226
i just disassembled the front sus. and put it back up and the slop was reduced considerably, it has about .5mm now, looks like the belt tensioners was the cause of the slop and the diffence between one side and the other.
#7227
Originally Posted by litespeed-dom
Actually the setups have been on the old site, just that no one ever really got on there.
I actually think they just opened Shopatron now.
T-shirts.... everyone should get one, they are way cool. Just make sure when you guys order the team shirts, put a note on the order that Dom told you about it so Joel knows I'm doing my promotion part of the job! While you are at it, don't forget the pit towel!
Dom
Dom
You think we can have a pit towel that just says "KYOSHO"? The current version with the EVOLVA WORLD ChAMP stuff is okay, but I don't even run that car. Also, it says 2005 and gives the impression of a dated product. Can you get the ball rolling for a new pit towel? I think the kyosho in you avatar would be a great template to use.
#7228
i never oil up my one-way bearings. i find they get greasy by themselves and i really couldn't be bothered
#7230
Cheers all for your help. However...im very new to all these adjustments.. Ive just come from a rs4 that didnt have many things to adjust.. couple more q's if i could.... How do i adjust the droop.... u said track width.. where do i measure this distance from.....rear sway bar soft like 1.8 or softer ???????? does anyone have a "Setting Data Sheet" they could e-mail me.. Thanks again for all your help... I will start doing all that other stuff now and i will see how i go.
