Kyosho v-one rrr
#3406
Originally Posted by NiMo
Due to demand a second limited batch of WC kits were made available.
There are only 3 versions of the RRR chassis kit, the standard, the WC, and the Rubber spec.
BB
#3408
Originally Posted by Bundy_Bear
NiMo: Have you run your RRR on rubbers yet? Or are you just using the FW05 for rubbers?
BB
BB
RRR for Foam racing (too nervous on Rubbers)
Both cars are still in use but used in different classes.
RRR give adrenalin rush.
FW05 is relaxing to drive.
#3409
Hey guy's just got a wce on order and was wondering who makes a good battery pack for it? Is the battery size 2/3 a's ?
#3410
I would the Battery Pack that Skyline Racing makes. (14000 Mah Flat Pack)
http://www.skylinercracing.com/store/C_24.htm
Never ever had any issues with it. And will definitely last you even thru a 1 hour race. Hope this helps.
#3411
Thank's Ronni, for your help. should've picked some up from Atomic at nat's.
#3412
FW05 for Rubber racing (not aggresive enough for foams)
BB
#3415
NiMo: You think even with the Rubber edition RRR the FW would still be better?
BB
BB
From what I've seen of Parking Lott tracks (not race on one since KWC Hawaii 1999) you'll need a quick turning car so maybe the RRR on Rubber would be the choice.
#3417
Marco..that's to take away front traction. We used that to help with traction roll.
#3419
#3420
Hey Joe, did you have fun at the Nats?
Some people also do that to their front tire here at Revelation to avoid traction roll. I haven't tried it as the most I had to do was to run 45 front.
