Kyosho v-one rrr
#3181
Originally Posted by jwf_frani
hey jeff, were you out of town again. just wondering since i didn't see you at revalations this week end.
#3183
Originally Posted by Kyle Hazell
Its pretty much common knowlege that these engines break the crankpin off. Simple as that.. We had a Worlds edition engine that was run in, did one race meeting with reasonable performance and then broke the crank pin off the next time it was run. I have seen many more that have failed in this way...
The thing to remember in all of this is Sirio (we all know who they are) are in their infancy, and these things are going to happen. Many people will remember the debarcle we all had when the long stroke engine was developed back in the mid 90's. I remember going to a major race meeting and hearing all the cheers as one after one they all detonated down the main straight..... from memory we all ran out of engines....
As for carb leaks, well our experience tells us when you get a good carby stick to it. Carbs are a bit of a lucky dip...
Sirio will fix this problem in due course. The quality of their work is second to none, in fact i think it has been adressed on the latest spec engines.
Regards
Kyle
Regards
Kyle
#3184
Originally Posted by jeffreylin
That adjusts your front castor angle.
jeffreylin - are you talking about the caster clips? i'm talking about the small palstic that got 4 smalls holes that holds the hinge pin.
CE!
#3185
2 bits of news from me:
I finally got a day without rain to race my rrr with new 7075 chasis. (been trying for almost a month now ) I absolutely love it. The tracks I run at are smooth with decent traction and on sunday the car was dialed. the new chasis seems to take out the super aggressive dive/turn in that the rrr can have sometimes unpredictably. i also felt it could be more hooked up and run a bigger rear droop without feeling the danger of highsiding that alot of rear droop can sometimes give. this also made the inside tight and fast line seem more drivable. so with a few setting changes and a few practice laps i was really loving it. i finished third on the day behind a pro driver that showed up outta nowhere to clean up and the track's local fast guy that also drives at the pro/ semipro level here in japan. On top of this I was really happy with my driving. i touched two corner markers all day with only minor roll overs . part of this was because I was using my backup/backup OS.12 tr mod. It doesnt have near the rip of the other engines but it was faster and easier to handle on the tight and very long infield section at my track. so in all I have two big thimbs up for this new chasis....but make sure your bats are well charged because it is a job to change them out.
the second is a coment about the sirio evo 2 worlds. This motor is insanely fast! It really is a missile. At the three local tracks I drive at 4 of 12 sirios have had massive crankpin failure that totally grenaded the engine... part of it is because the engine revs to the moooooon and will rev till it explodes. If you dont tame the rpm with correct gearing it will grenade. i also feel that there is a bug that needs to be worked out with the crank.... maybe it is too hard or etc etc but to have a quater of these engines fail exactly the same makes me think something is up. All these drivers are experienced and have been racing for a very long time so it isnt bad tuning /abuse.
happy racing.
happy racing.
#3186
CE!
CE!
#3187
Originally Posted by kewdawg
Common knowledge to whom? You're telling me, that you think the crank issue is purely bad craftsmanship or poor quality? Is there a thread on r/c tech for this engine? How many people are saying this (other than those in your immediate, geographical area)? I've had my Sirio Evo 2 World's Edition for three months, ran a little over a gallon thru it and the engine runs insanely strong from start to finish. Feels like I got damn HEMI in my nitro touring car!!!
Im glad your engine has not detonated, you have got good value for your money. The same can't be said for a lot of other people...
Regards
Kyle
#3188
If you read around you will understand why its common knowledge. Im not telling you anything other than there is a problem with these engines and they detonate.. The reason for that, well i dont work for the manufacturer, nor claim to be an expert in crank design or the materials used/processes involved so i cant answer that.
Regards
Kyle
Regards
Kyle
#3189
happy racing.
happy racing.
My 2 copper pieces.
#3190
This is why I said "user error" could be a possible culprit. Name any high performance engine that won't detonate, if, allowed to rev to the moon for any extended lengh of time?
My 2 copper pieces.
My 2 copper pieces.
my 2 yen.
#3191
When you guys say "detonating" are you reffering to engine failure or detonation associated with combustion? I have seen my friend's Collari show excessive wear on the crankpin but that was because it was undershimed. Perhaps the engines you've seen fail are undershimmed. An undershimmed motor will incur the most damage during break in.
#3192
Sirio have been winninig most of the time in my country and so far I have not come across any problem other than some leaky carb from EVO 1. Even since the EVO2 was out, everything seem to be done right. Apparently some of the drivers have been running the EVO2 for the whole race seaon with the original conrod. The 2 top drivers from that team have been racing the M.Collari EVO2 for 7-8 races now and still going strong.
I dun really think the Sirio have problem, perhaps wrong gearings or fuel with too little oil could be the problem.
#3193
That adjusts the roll center.
#3194
Thanks and I understand that there is no way I can adjust front kick up and this tuning option is only common to EP cars,right?
#3195
sorry i shouldnt have used detonating.... i meant breaking of the wrist pin. I havent driven one, or messured the head clearance so this could be very possible. Maybe it is all driver error but I just wonder why other engines arent doing the same. anyway i think it is really fast... the fastest engine i have seen run and I dont even have a complaint i was only commenting that I have seen the new sirios blow up too.
anyway back to the rrr
