Kyosho v-one rrr
#3331
Originally Posted by YBSLOW
Just make everyone start the race using a spectrum, then you will have a broken car race.
Whats up with the Spektrum? I thought it was supposed to solve all the interference problems?
#3332
Spektrum
I have the latest release, and my still likes to go into faisafe and sit there untill you turn the car off and back on and also likes to stick in full throttle position aiming for the wall with no steering. New Ko Helios and all new spektrum system.
#3333
#3334
Originally Posted by svines1972
I, only problem I have found is trying to figure out which screws go where. Drawings are close to the actual sizes, but may need to buy a caliper to make sure I am using the right ones. .
#3335
I have the Spektrum in all my kits and never had any issues.
#3336
Thanks for the help. Ya, I guess 80% full was a bit full like the instructions say.
The Kyosho vented rotor I think was about 3 grams heavier.
#3339
Originally Posted by rodneybarrett
Anyone having clearance issues with the front foam tires(26mm) and bottom shock cups?
I had to eventually use wheels spacers to get the tires from rubbing. I tried just extending the knuckle but then the bone kept coming out of the drive cup.
#3340
You beat me to it Jeffreylin
I have found this car works best with less steering turn which just happens to prevent the wheels scraping the shock cups.
I have also slowed the speed of the steering servo as the fast speed made it nervous.
These settings are the total opposite of an FW05 set up.
#3341
lol NiMo, it's like racing you without being there.
You ever race outside of UK? Maybe one day I'll race against you in one of the big races...
#3342
#3343
Gearhead3:
I think the WCE rrr has those cvd's.
I agree in principle on the less steering the better the car but I can't seem to find a good combo that still gives good rear grip.
I will say though, I have finally gotten the car to run faster lap times than my G4. So....I think I'm on my way.
#3344
Hey guys...I've had several PM's & e-mails asking for a RRR bumper and thought I would let everyone know at the same time that the RRR bumper is now available http://www.pdubracing.com/products.htm
#3345
also, as a last solution you could set some exponential steering curve to make the steering less nervous around center.
Regards,
Arvid
