Kyosho v-one rrr
#2387
How can you tell?
#2388
Originally posted by Racing4Evo
Has anyone tried the new Kawahara rear swaybar? I'm wondering if it is harder than the copper bar when set vertical.
#2389
Thanks.
#2390
WHAT OUTDRIVE WILL I USE IF I WILL BE USING A FRONT DIFF
#2391
VZ218 Differential Joint (19)
#2392
Location: Cebu City, Philippines and Ocala, Florida, USA
#2393
Originally posted by doki_doki
pare...you can check it out sa manual. there's a section there that tells you what stuff to order in order to run the kit with a front differential...
#2394
#2395
RRR WC Team Edition
Does the RRR WC ed. come with a shimo chassis? It seems to me that most shops now sell only the WC ed. and not the RRR...is kyosho gonna come out with a new model? Just to find out more before i commit buying one. Cheers.
#2396
Re: RRR WC Team Edition
#2397
Re: Re: RRR WC Team Edition
Originally posted by jeffreylin
There isn't a Shimo chassis for the RRR. If you can get the WC get it as that is a bargain compare to hopping up the regualr kit and it's no longer in production.
I am also considering the 05RR, just can't make a choice. How do you compare the 2 in terms of acceleration and cornering speed? I had some bad experiences with my RR evo that fishtails whenever i do cornering off-power.
#2398
Re: Re: Re: RRR WC Team Edition
Thanks Jeff for the advice. Just to clarify, which one is no longer in production? The regular RRR or the WC ed?
#2399
Hi GUys
I was playing with the RRR the other day at the local track....... and it was doing pretty good, until it was hit by another car and it cart wheeled in to the sand........ after a while i lost speed and the engine was revving and no speed at all.....
first i thought iwas a stone ........ then someoen said the clutch is gone......... later..... i found out that the rear belt had turned around... that means the teeth on the belt were on the outside. I was surprised at this. Was this a problem with the fixing or this happens? on the RRR.
Could i stop it from happening again ? waht should be done..
cheers
ZiiZo
cheers
ZiiZo
