Kyosho v-one rrr
#2356
Originally posted by wad
No
I was making 4.40 only
You think that can be motor problem??
No
#2357
Originally posted by jeffreylin
It could be that. Maybe your bottom is too rich and top too lean? What gear ratio and tire size were you running? At Rev I run 16/50 23/45 with 57F and 59R.
gears was 17/61 & 22/56, tire size was 58/60
I had really good speed with those gears, if possible I would like to keep them and change something else
#2358
I think your problem lies with the motor tuning. I've only had run time issues on BIG tracks but so does everyone else. How long is your fuel line Walter? Mine is 7 1/2 inches so try going longer if you haven't already. Next time, don't go full out modified with that motor!
#2359
I have a problem, I don't have any non-full modified motor left
#2361
Hi, does anyone know where get a copy of Cyrul's and Bertin's setup sheets from the last Worlds in Brazil ? Been looking around for it without much luck.
#2362
Kyosho Team setup - Japanese
#2363
I was pretty much lean on the bottom than normal, and I was little rich on top than normal.
#2364
I got the 23t gear. You can run small tyres and get really good speed with good handleing
Cheers
Cheers
#2365
Re: Front Knuckles
If I use the 2 degrees knuckles:
will I get more or less steering?
ON or OFF power?
entering or exiting the corners?
ON or OFF power?
#2366
Re: Re: Front Knuckles
You will get more on power steering. It's most noticable on corner exit. The car is a little lazy on corner entry with the 2 deg. hubs.
#2367
Re: Re: Re: Front Knuckles
Originally posted by joemugen
would you say the 1 deg would be a better option then?
Anyone that finds the car really nervous off power should change to the 2 deg. hubs because they get rid of a lot of that. Also, there is nothing wrong with lowering the dual rate on your radio. The less the wheels are turning, the less they are scrubbing which will mean better tire wear. I have mine set at 75% for my home track.
#2368
Re: Re: Re: Re: Front Knuckles
It depends on how you feel the car is handling. If you just need a bit more on power steering then the 1deg. hubs should be perfect. It doesn't hurt to try both if you have the time and decide which is better.
#2369
I've already experimented with the 12 ackerman arm but I didn't like the way it handled. The car had very little off power steering. The 11 is best, but I have heard that the Kawahara arm is better since you can adjust the postions forward and back as opposed to narrow and wider with the stock arms.
#2370
I thought the 11 would hit the diff housing, so I put on the 12.
Not yet finished the car so I cant say if it would work but would this off power feel be anything like the FW05 off power push?
