Kyosho v-one rrr
#1606
Originally posted by AndyT ©
Its quite an easy build, but heres a couple of tips-
* If youre running a Protoform Mazda 6 body, mount the rear body posts on the inside of the shock tower otherwise they`ll come through the body under the rear wing.
*Section 15 of the instructions shows the brake discs being fitted into the wrong hole......have a close look and you`ll see the correct hole to mount in to.
* The stock centax clutch setting was too heavy for my liking, I wound mine out about 1/2-3/4 turn and its perfect now
* The 2 speed recommends to wind out the screws 3 turns from fully wound in. I found this was way off for the tracks i race on. Between 4 turns and 3 3/4 turns is ideal for me.
* Get the Kyosho Aluminium brake hub (VZW205).....if it doesnt already come with the WC kit.......the plastic ones tend to melt if they cop too much heat.
Hope this helps a bit
Cheers
Cheers
#1608
surge,
thank you for the compliment on the shock tower.
#1609
Re: Diff Oils
Hi there I hope SOMEONE can help me!
Im builing a WC kit just now, and race on a tight, med-low traction surface.
Im going to use the fron diff as I like front diffs, can anyone recommend front and rear diff oils to run as a good starting guide.
30,000 kit rear seems way to stiff to me, can u even turn that?!!!
Thanks in advance
Ross
Thanks in advance
Ross
#1610
30000 works great in the rear diff. It feels a little light to me but worked fine, even at the Winternats with crazy traction. I'm not sure about the front, maybe heavier if you want less steering but lighter if you want more steering. I think the solid axle is the best choice though.
#1611
tamiya xbg or kyosho fwo5s
hello guys!
im new and i want someones help about which rc car i must choose.im not thinking to race or modify a lot the car.wich car seems faster and without lots of problemsill apreciate if someone tell me
thank you
thank you
#1612
Im just trying to establish whats going to be best for a tight, technical track that isnt sticky black asphalt like the good circiuts.
I suppose the traction could be described as parking lot.
What would be the advantage of the solid front vs a diff ?
Thanks!
Thanks!
#1613
help
my friend can you give me an advice about this 2 cars tamiya xbg and kyosho fw05s?wich i should choose?
thank you
thank you
#1614
Kyosho no contest
#1615
jwf_frani
Thanks for the info. From looking at your aviatar it looks as if you're from Brea, so I assume you probably race at Revelation Raceway. If so can you tell me does the kit diff oil work their or should I go lighter/thicker. Also how close is the kit setup for that track. One last thing, are you guys running Kyosho shock springs or others.
Thanks,
Keith
Thanks,
Keith
#1616
Originally posted by rcfiend
jwf_frani
Thanks,
Keith
jwf_frani
Thanks,
Keith
#1618
Jeffreylin - thanks. Should I buy extra springs?? If so, should I get the Kyosho springs, Associated, etc.
Keith
Keith
#1619
Originally posted by Diesel Racer
Hi D,
It was Spain we were going to but the bloody wife changed her mind, I tell you I'm well p@**ed, the villa is nearly finished and we were meant to be moving over next month.
Looking to buy another on-road chassis, I really liked my 710 but also quite like the look of the RRR, just not a great fan of standard planetary diffs.
Cheers, Mark
Hi D,
Cheers, Mark
.. or stay here and learn to speak Chinese.... Dont say i didnt warn you!
Cheers
#1620
Re: help
thank you
thank you
