Kyosho v-one rrr
#2116
V1RRR
some pic of my RRR...
#2117
V1RRR
others pic... with servo and receiver...
#2118
V1RRR
last pic.
#2119
Nice but i think your pipe should be lower the fuel and oil will build up in the middle
#2120
V1RRR
V1RRR using serpent bodyshell...
#2121
Originally posted by sjr456
Im running the skyline vr12 on my RRR, its a good pipe. Its as good as the RB I was running previously, and a bit sturdier. Twister tires work well. I believe the foam is from GRP, so traction is good but wear isnt quite as good as Monotuning. Also the rims are really strong.
I run Twister tires from Kinetix also. They're great tires, especially the wheel. It's really sturdy. I went through a crazy accident on the straight last weekend and the tire was barely wobbling even though the pipe on that side was destroyed.
#2122
Location: Cebu City, Philippines and Ocala, Florida, USA
Originally posted by rcfiend
What is the common pipe that everyone is using on the RRR. And has anyone ever heard of Twister foam tires. They are selling them @ $9.99 on the Kinetix website. Just wanted to check before purchasing some.
#2123
Re: Re: Re: part to convert ruuber tires to foam tires
Originally posted by buboy28
DOKI: any feedback using the rubber tires i'll be running mine with foam tires when i finished it
#2124
#2125
Originally posted by joemugen
twister is not made my grp... they also are not nearly as consistent as any grp tyre (eligi, fast tyre, rs tyre). if possible, go with grp!!!!!!!!
The rims are by far the strongest I've ever used. The rubber is great. Provides good and consistent traction.
BTW...you missed a good weekend at the last race. Traction was almost at Winternats level and alot of guys were on the verge of traction rolling.
#2127
Originally posted by JustRace
Joe...I disagree with that. Twister is a great tire. I've not had any problems with consistency. You should talk to Omar if you had any problems. I'm sure he would work it out with you.
#2129
Re: Best Body for RRR in the Outlaw Class??
Originally posted by bighurt98
I was wanting to know what the best 200mm Can Am body to use on the RRR for the Open Nationals at Kissimee this fall?
#2130
I believe twister is made by GQ...
