Kyosho v-one rrr
#2101
Location: Cebu City, Philippines and Ocala, Florida, USA
Re: part to convert ruuber tires to foam tires
Originally posted by piorc
Hey guys, i just bought my v-one rrr rubber tires edition, and i want to convert it into foam tires version.
What parts i need to do this??
Any one knows??
Thanks.
Marcelo.
Any one knows??
Thanks.
Marcelo.
#2102
Any one knows??
Thanks.
Marcelo.
Any one knows??
Thanks.
Marcelo.
#2104
Originally posted by rcfiend
What is the common pipe that everyone is using on the RRR. And has anyone ever heard of Twister foam tires. They are selling them @ $9.99 on the Kinetix website. Just wanted to check before purchasing some.
#2105
I would also like to know what the good pipes are.
What Skyline pipe are you talking about? Is it the leagal or the outlaw one?
#2106
The Max is good too but more expensive and not as sturdy.
#2107
Is anyone out there running the front diff with overdrive (23T)? I wanted to get some feedback on this. Also if anyone has any opinions on this it would be appreciated.
Thanks,
John
Thanks,
John
#2108
#2109
I`m running the RB pipe (V- concept 401) and find it to give pretty good power right across the board with my RB v12.
#2110
Im running the Mugen 2501 EFRA and ive found it to be the best pipe ive ever used.
Ive used Nova, Jp, Max, RD, mega and none come close to the Mugen
Very strong aswell
Very strong aswell
#2111
the best is efra 2601
#2112
Re: Re: part to convert ruuber tires to foam tires
Originally posted by doki_doki
by the way, can you post what are the recommended settings for the rrr with rubber tires??? thanks
#2113
set up for rubber tires
hey doki_doki....
I'm from Brazil , so i we usually use sorex 36 tires, soften suspension, use front diff, and the greater racers blocked front diff (spool) , these are the basic.
But some guys change front sway bars, rear axle, all pulleys ( i was talking with a guy here and he told me that rubber tires version comes with litlle pulleys than foam version).
But i tested those ways and didnt found different results.
Tell me one thing, what engines do u guys use in the us?
i'm using here novarossi rex rer 12s3 with efra 2601 pipe.
Thanks.
Marcelo.
Thanks.
Marcelo.
#2114
Location: batang kalokohan! ay kaloocan pala!!diretso ka lang,pag nasaksak ka! bahay na namin yung sa harap!
Re: set up for rubber tires
Thanks.
Marcelo. [/B]
Thanks.
Marcelo. [/B]
And bout the pipe mostly racers I see using skyline pipes and this what I'm using now.
#2115
People also use Sirio Evo2 and STS D3R here.
