Kyosho v-one r4!!!!
#782
fuck!your eyes are like these in your avator!xxxx
the receiver box is the m-mod for the mugen mrx4,and the middle pulley set up is from the rrr,i use the pulleys from it,and the hollow shaft.i cut it,and make a second line to secure the c-clip!
with this i gain 10gr rotation mass!!it's noticeable amount.
next is the rear shaft and pin type pulley for another 10gr gain.AT least!
#783
#784
#787
Can you put more details of your transformation?...
Code parts... images?...
#788
look,you need one kyosho pulley set from rrr,code vz203 because you need the 18t pulley that is included in the set.then you need a kyosho vzw056 hollow middle shaft.then you leave like it is in the pipe area and you cut it from the servo area,but you leave 2-3mm from the pulley so you can make a groove to put the c-clip.
#789
Interesting conversion on the middle shaft using the RRR hollow shaft. I wonder if I could do this conversion on my RRR using the R4 middle shaft mount????
Has to be a lot easier to change the front belt with the R4 mount..
#790
Here are some mods that I've done to the transmision of my R4...
Pulley Mod V1.0...
Now I have stronger tools, so I would try another mod to the pulley so I can reduce the rotation mass a lot more...pulley mod V2.0 coming soon...xD
Pulley Mod V1.0...
26Likes
