Kyosho v-one r4!!!! >
Kyosho v-one r4!!!!
Like Tree26Likes
Kyosho v-one r4!!!!
Old 07-20-2025 | 11:42 AM
  #931
impalabob64's Avatar
Default My diff build and clutch end play
Originally Posted by jcalchi
impalabob,
Since you just did your build, did you have any issues with your diffs leaking?
I noticed diff fluid accumulating on both front and back belts, so I ordered some new O-rings and rebuilt the diffs and that seems to have fixed it.
Looking at the design, it’s easy to not get the O-rings in the right position, and easy to mix them up. Good thing Kyosho still supports parts for this car.
Another question: how much axial play does your clutch bell have? The spec shows that there should be some. Design-wise, any thoughts on why Kyosho wants axial play on the bell? I’d think there shouldn’t be any at all, and that the play would delay engagement of the clutch.
Thanks,
jcalchi
For my diff build i used black rtv before putting the diff together no leaks, i used a nice smooth layer of rtv ,and as for as my clutch bell end play very minimal play the engine im running is the Emx Wc picco 12 the gearing im running is16/60 21/55 tire size 58/60 CZ1 body, diffs 1,000,000 front 100,000 rear here in Florida the traction get pretty high, soon I will test a locked front diff will keep ya posted .
impalabob64 is offline
  #932
impalabob,
Thanks,
jcalchi
For my diff build i used black rtv before putting the diff together no leaks, i used a nice smooth layer of rtv ,and as for as my clutch bell end play very minimal play the engine im running is the Emx Wc picco 12 the gearing im running is16/60 21/55 tire size 58/60 CZ1 body, diffs 1,000,000 front 100,000 rear here in Florida the traction get pretty high, soon I will test a locked front diff will keep ya posted ,hopefully this helps.
Old 07-21-2025 | 06:34 AM
  #933
Default Also forgot
I lightly sanded the diff housing also you will see the high a low spot sand till smooth and even
Old 07-22-2025 | 03:49 AM
  #934
Default O.S. Speet T1204 and Swing-Style Clutch Weights
Originally Posted by SickDuc
MS isn’t very precise on his clutch build for someone new I think, “and for the nut, honestly I don’t know” haha
To OP, which engine are you running?
I can give you my settings as a starting point, but as Roelof said, they’re suited to the track I’ve been driving at.
SickDuc,
To answer your question, I'm running an O.S. Speed T1204. Beautiful little motor. Been in love with O.S. Engines for forty years. Had to buy this little gem, as my old FF-320 Pegasus from a retired plane was overkill for 1/10 TC.
As far as my track, (and settings suited to a track), I'd like my baseline setup to be suited for easy driving on a blacktop parking lot. Unfortunately, there are no real on road racetracks in St. Louis, MO. When I say easy driving, I mainly mean I want the car to start moving (clutch engage) at a lower RPM, rather than having to wind it up before it even starts to roll away.
The modern clutch in this car is way more sophisticated than the clutches on all my old 1/8 scale cars: RC300, RC500 and Kyosho Vanning. Back then, installing the clutch on a K&B motor intended for an airplane usually required the use of a Dremel tool. And the only parts were the bell and two stamped metal shoes and a strip of material for the liner
I do love how Kyosho provides cross-section views of the clutch. That's helped me understand how it is supposed to work: the split (cut into three separate weights) clutch weights don't actually engage the bell at all, the centripetal force throws the weights outward (transversely), and by their angled face, they push axially away from the flywheel, and thus push the other weight (the one that is not cut into pieces) against the bell.
Considering track conditions, do the two different configurations of clutch weights (swing-style versus push-style) really behave that much differently?
Thanks all for the good information.
jcalchi is offline
Old 07-22-2025 | 04:10 AM
  #935
Default Clutch Gap Versus Play
Originally Posted by Roelof
Adjustments to clutch and gearbox are needed to suit the track, also when different gears are used it will affect the shift moment.
Regarding the clutch, probably you have set a too large gap, the gap is the distance of the shoe to the clutchbell and requires the right way of measurements and shimming. Look up the Youtube video by Michael Salven about the Centax clutch.
OK, watching Michael Slaven's video really, really helped me understand a few things.
The key takeaway for me is that there is a difference in the gap and "play". On page 34 of the manual, Step 60: "Step A" looks like that's the gap, and "Step B" is the play. As Salven demonstrates, he gets the gap set first (without bearings in), then adjusts for play after the bearings are installed. How I got so mixed up, was I was trying to shim and adjust all at once in one step.
I usually like to learn from reading rather than watching videos, but this time, watching Salven build his clutch really cleared things up for me.
Thanks for the useful information. I'm going to watch some of his other videos.
jcalchi is offline
Old 07-22-2025 | 04:24 AM
  #936
When I look at the R4 manual I must say it is not clear at all. With the drawings no dimensions are given but it is written in the sidebar. Also a gap of 0.4mm is given but that is too low, more like 0.6 is needed to get a decent clutch. Also shimming under the clutchbell is a bit unclear, If I did understand it right you must shim until there is no play but you need play or otherwise due expansion of the clutchbell it will bind itself.
(Just catching up on all the replies to my posts; awesome information, and really fun to learn new stuff. Yah, Internet!)
The R4 manual to me is better than some others. But the pages on the clutch install could be more clear, proper dimensions on the cross sections, etc., rather than in the translated from Japanese side bar notes.
What helped me somewhat, and no joke here, was to open the PDF of the manual, and zoom in real close, and stare at it for a while with the parts on my desk. The sequence of installation, adjustments, and re-shimming, etc., could be better described along with proper dimensions and clear up some confusion. But sometimes the trial and error method and learning curve I'm climbing is a really good way to fully learn both the how and the why behind this. These things are too complicated to just blindly snap things together like a Lego set, and miss all the really important know-how of how the car really works.
Along those lines, I never bought my sons a RTR car--always a kit they have to assemble themselves. This way, they understand how it works, and WHEN something breaks or doesn't work, they know how to fix it--like a good mechanic.
I just got caught in the weeds with all the fancy modern workings of this clutch and 2-speed transmission.
Thanks all for the info!
jcalchi is offline
Old 07-22-2025 | 09:33 AM
  #937
SickDuc,
So I just had a track day( high traction asphalt) and my clutch was set up swing style with the flywheel nut threading sticking out the clutch nut 0.6mm using the clutch spring supplied with 2 lines in it/1.8mm thick. That made the clutch engage just how you described you want yours ( we have the same engine). MS building the centax clutch isn’t much the same as kyosho’s but the idea is the same, have to get to the same outcome. As far as the gap, just add shims until it’s snug then remove the amount for desired gap( for example if you want .5mm and 1mm makes it snug/wont spin, remove .5mm of shims)..
I have used push style as well, the swing style felt more aggressive and maybe even too aggressive for very high grip..,IMO of course
As your clutch is now, when you are driving and you want the clutch to engage sooner, you can tighten the clutch nut spring through the little hole on the clutch bell. Line up the bell and notch in the nut and tighten about 1/8 of a turn, test drive and repeat if needed
SickDuc is offline
Old 07-23-2025 | 04:32 AM
  #938
SickDuc,
OK, that is a great post. You couldn't have been more clear with the how and the why. Very helpful. I just wish I could go out to my workshop today and play with the car. But I gotta pay rent. I'll play around with it this weekend and maybe report back. At this point, I know building and adjusting the clutch gap and play is no longer trial and error, and involves precise measurement and math for what shim to add or subtract. And adjusting the gap first, then the play in separate steps is the key. I think the manual tried to convey that, but not really.
For anyone else reading this post, go ahead and go to Kyosho's website, and order the shim pack for this car. I ordered two packs on impulse buy when placing an order for other stuff. But now that I know exactly how to do the math to determine exactly what shim to add or subtract, it's easy, especially since I have lots of spare shims. The kit leaves no spares (if you drop one of them). And when I first built this car, I only had an Imperial Units caliper. I bought a metric dial caliper, and that takes all the guesswork out of this. You can kind of feel with your fingertips which shim is which, but 0.5mm makes a big difference. Get a metric caliper if you don't already have one
Thanks again,
jcalchi
SickDuc likes this.
jcalchi is offline
Old 07-23-2025 | 05:53 AM
  #939
Roelof's Avatar
These clutch shims are just normal shims you can find on Amazon etc. Last I have bought bags of 100 pcs in several sizes.
SickDuc likes this.
Roelof is offline
Old 07-31-2025 | 06:37 PM
  #940
Default 2nd kit came in today
Backup kit on the bottom also going to test bittydesign hyper 200
The RRR first gear spur fits perfectly, and the RRR belts are the same,so if anybody is running the r4 the RRR belts and the first spur gear im ,the second gear may work but may have to modify it some
The RRR first gear spur fits perfectly, and the RRR belts are the same,so if anybody is running the r4 the RRR belts and the first spur gear im thinking the second gear may work also but may have to modify it some i will post pics of what I did to get second gear spur to work ,Im thinking with rrr spurs maybe little lighter im my opinion.
im using the blade bar from the RRR easier to setup with it 👌
SickDuc likes this.
Old 07-31-2025 | 06:40 PM
  #941
Default Bodies
Bittydesign
Old 08-11-2025 | 04:52 PM
  #942
Also, worth noting that the top deck is 5mm lower than the Evo 2, and the diffs are smaller, plus the 2-speed shaft is lighter. This combo will definitely spool up quicker, kinda like the...
Gnito53 is offline
Old 08-13-2025 | 01:59 PM
  #943
how do you set the front roll bar? I can’t get the sides to lift equally for the life of me.
SickDuc is offline
Old 08-13-2025 | 03:05 PM
  #944
Default Yes it does
it does spool quicker that for sure im running the Picco Emx wc 12 -16/60 21/55 .
Old 09-09-2025 | 07:00 AM
  #945
Default New crazy build on the way
Well ,the name i came up with is Kyosho V1RRR4EVo3 Bobby,s edtion lol I have brand new Shimo kit and brand r4evo3 kit will be taking r4evo3 drive train in putting it iall nto the Shimo edtion kit and we will see what happens
