Old 09-01-2012, 12:30 AM   #751
GREGORY!'s Avatar
Originally Posted by Highside20 View Post
I agree, I'm not sure why kyosho went with the Evolva style pulleys. I think the old style RRR pulleys are way lighter.
i think that he use the sr rear axle and rrr evo 2 center rear pulley compo.a cheap solution is to drill the alum adapters in evolva style like nt1's light versions.
i have a r4 with life,carbon wheels,some titanium rods,low prof throttle servo,side and rear weight and is at 1710gr.my rrr was lighter.so i am searching for reduce weight.
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 09-02-2012, 08:26 AM   #752
Originally Posted by GREGORY! View Post
some photos of your car?
here you can find some photos...
http://www.facebook.com/media/set/?s...2946930&type=1
TomasRC is offline   Reply With Quote
Old 09-10-2012, 08:22 AM   #753
GUINT1's Avatar
Quick Qns I have.
Is there any kind of up grade or a
Replacemet stock servo horn for steering.
This stock servo horn has broken on me several
Times. I also thought that Servo saver should have absorb
Most of the impact. Long story short this is like the
5th time replacing it.
Empire Racing/Maxy's fuel/Ko Propo
Motor. .21 FLASH/353 Race
Body. Zytech/P909
Tyres. Ky Red Box
GUINT1 is offline   Reply With Quote
Old 09-10-2012, 10:55 PM   #754
GREGORY!'s Avatar
i use the serpent 966 plastic part with no issues.hey guys!i have notice that this car has a lot of flex in the front and the rear in areas that under pressure change the geometry of suspension.it is the reason why they came with these aluminium upper parts.
Old 09-11-2012, 02:52 AM   #755
GUINT1's Avatar
Thanks. I will try it.
Body. Zytech/P909
Tyres. Ky Red Box
Old 09-11-2012, 09:28 AM   #756
Originally Posted by GUINT1 View Post
Quick Qns I have.
I have been using the RB5 servo arm (LA221HB) with good luck. I just had to move the servo inward (toward the middle of the car) with around a 1mm shim to assure the same geometry as the original.
MHR
Highside20 is offline   Reply With Quote
Old 09-27-2012, 03:42 AM   #757
esham's Avatar
Originally Posted by TomasRC View Post
Good News!!! after a few races with rear diff problems I have tried the steel diff gears....just perfect!!!...
1st Place Again!!!, Lap Record, Track Record and TQ!!!... the hole pack to V-one R4 /Team Orion Alpha ABI!!!...
Yeah Yeah!!!
http://www.minituerkasrc.cl/wp/?p=680
Congratulation Tomas..
Kyosho R4/V1RRREvo2/ OSpeed>Nova353T & S/Evo4M>Nova-KeepOnS
Transponder Pokok Cherry- [email protected]
Kelab Peminat Kereta Kawalan Jauh Ipoh, Perak
esham is offline   Reply With Quote
Old 09-27-2012, 12:16 PM   #758
GREGORY!'s Avatar
browsing in the network i fount that picture:http://pxf01445.bbs.coocan.jp/?m=image&image=893_1.jpg.
i think that it is a V-one R4 minor change part set.
Old 09-27-2012, 12:26 PM   #759
GREGORY!'s Avatar
and some photo from shimo's car.
Old 09-27-2012, 12:27 PM   #760
GREGORY!'s Avatar
Old 09-28-2012, 06:32 PM   #761
Did you notice the order of the hole pulleys?...they are not normal way to install them...
Old 09-29-2012, 10:12 AM   #762
GREGORY!'s Avatar
do you mean the different way that he put the pulleys in the middle belt?he put them that way because some manifolds run so close on the middle belt.
Old 10-13-2012, 10:09 AM   #763
kest's Avatar
Trader Rating: 1 (67%+)
Post
This is my mod on the rear stabilizer holder..made from 2mm plastic (servo spacer)..the standard shim restrict the stabilizers movement.
K..Y..O..S..H..O..I..S..H..O..B..B..Y
JBRCC
BCRT
kest is offline   Reply With Quote
Old 10-18-2012, 04:21 PM   #764
GREGORY!'s Avatar
hi guys!one notice for this car.when you set the front downstop you must measure from the down shock mount,but from the hole.i have put a long set screw there so i can have accurate setting. i hope this is helpful .
Old 10-18-2012, 04:23 PM   #765
GREGORY!'s Avatar
do you use aftermarket brake pulley??
**NSWRCRCC Inc. - Moorebank On-Road** VenomWorldOrder Australian Racing 11447 11-30-2017 04:03 AM
Kyosho FW-05R Finnitro Nitro On-Road 5443 02-07-2017 11:10 AM
Kyosho V-ONE RRR EVO 2 boy2rc Nitro On-Road 2803 10-04-2014 12:50 PM
Kyosho V One Series Prototype (;) nikoskar Nitro On-Road 78 12-16-2010 04:07 AM
