Kyosho v-one r4!!!! >
Kyosho v-one r4!!!!
Kyosho v-one r4!!!!
Old 01-01-2011, 01:08 AM
  #31
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Default greasing
Originally Posted by DJ_Shakespear View Post
I would use grease if it wasn't for the area I race in!! Constantly dusty, so that would increase the wear rate I guess.
Unless... I just had a brainwave!! What if their was a rubber-like boot you could put over the driveshaft and the diff outdrive!?? The pins in the axle where the wheel is last me a long time, Ive only replaced the front uni's because they were gone on all holes.
What would be a good grease to use on those joints? I have Castrol HTB grease that I use for the Thrust Bearings, but would that be OK for the joints?
i use the white lithium grease it not real thick so it does get slung around, as far as dust covers i know a riend tried shrink wrap it seemed to work but for me it seem like to much trouble, just clean and regrease for me
I don't think the dirt in the outdrives is the same as dirt in your bearings, it will kill a bearing but in the outdrives the important thing is to keep the two metals rubbing dry.
Speedypeterb is offline
Old 01-05-2011, 05:45 AM
  #32
blount's Avatar
Default R4 Updates!
Stabilizer:
Blade-type on front (slightly longer reach). Rear features new design, shorter reach wire-type. Combines the sharpness of adjustable type with the simplicity and esilience of the wire-type.
Wheel hub:
Features the popular machine cut hexagonal aluminum “Multi Off Set Hub” from the Shimo Edition.
Bumper:
New structure. No longer connected to the front bulkhead so drops slightly on initial impact, and isolates the stress of impact from the bulkheads for more durability.
source Kyosho
blount is offline
Old 01-05-2011, 07:29 AM
  #33
GUINT1's Avatar
Hey guys
Just trying to get up to date.
Is there any news to when the new
car will be out?
GUINT1 is offline
Old 01-05-2011, 08:26 AM
  #34
blount's Avatar
Originally Posted by GUINT1 View Post
Hey guys
car will be out?
The end of Feb11. About 45 days from now!
blount is offline
Old 01-09-2011, 09:01 PM
  #35
rcabj's Avatar
uuuhh...counting the days
rcabj is offline
Old 01-10-2011, 01:38 AM
  #36
Mie3R's Avatar
Mie3R is offline
Old 01-21-2011, 08:08 AM
  #37
blount's Avatar
About 30 days left, Pilots!!
blount is offline
Old 01-21-2011, 09:38 AM
  #38
Hey guys
car will be out?
You fiendin' for the 4R.....I see you.....
1FastVW is offline
Old 01-22-2011, 05:42 AM
  #39
use any thinck grease. you can buy automotive CV joint grease which will be thick enough and does the job. This idea that grease mixed with dust wears out a joint quicker than a dry joint is a falacy. what destroys the steel is the steel on steel contact and the friction. even a thin film of grease (thin enough were you think there is nothing there) is enough to protect the joints. even open joints tot he point where they wear substantially less with grease. put grease on all joints of the CVD, and you will notice it will wear a lot less. Clean it frequently if the dust freaks you out...but it won't do any damage if you leave the dust for two race days or more.
i did the test once where i ran with and without grease. i was extremely suprised at the amount of wear i got with no grease. basically whenever i greased the CVD i got at least x2 more life on all parts exposed or non exposed.
TomB is offline
Old 01-23-2011, 04:04 PM
  #40
Sweet-o, im using Losi High Pressure black grease for now until its time to replace them - very soon. Ill get some thick joint grease later on if the Losi stuff is no good.
DJ_Shakespear is offline
Old 01-24-2011, 03:00 AM
  #41
i want r4 !!!!!!!!!!!!!!!!!!!!!!!!
dowhile is offline
Old 01-31-2011, 04:01 AM
  #42
ITO NIEVES's Avatar
Only 11 days!!!!!
ITO NIEVES is offline
Old 01-31-2011, 04:36 AM
  #43
Originally Posted by ITO NIEVES View Post
Only 11 days!!!!!
OMI GAWWWWWD!!
Hmm, the R4 or the Capricorn??
Maybe the R4 so I dont have to sell my RRR and spare parts!
Old 01-31-2011, 05:28 AM
  #44
Apart from the release date, WHO is going to be one of the first to actually be selling to the general public? As in being able to buy online or in-shop (if they weren't sold out?) XD
Old 01-31-2011, 07:28 AM
  #45
blount's Avatar
In the US Kyosho America will sell it along with LHS's that support Kyosho. RCMarket will also have it for Asia. I'n not sure about Europe.
blount is offline
