Old 11-02-2011, 12:44 PM   #541
nikoskar's Avatar
Originally Posted by twinkie View Post
so with reading alot of this... I am now stuck in the middle... do I get a R4 or the Shimo edition?
Would prefer a mix of both.
Would be --->
www.rc-world.gr
nikoskar is offline   Reply With Quote
Old 11-02-2011, 12:46 PM   #542
this is a long thread... and I'm sorry if I'm repeating a question...
But before I start the build on an R4, is there anything I should purchase and install right off the bat?
Thanks... when I build this thing, I would like to just get it done the first time.
Thank you
twinkie is offline   Reply With Quote
Old 11-02-2011, 02:42 PM   #543
1evo RRR Driver's Avatar
Send a message via AIM to 1evo RRR Driver
Like Nikoscar said. I would prefer a mix of both...... But if I had to get R4 I would wait for awhile!!
My choice would prob be
Cap
Xray
shimo with xray diff mod n a cap clutch!! Would b a killer!!
Mug
Serp
Shep
R4
G4!
Ntc3
hpi rs4 pro2! So the ntc3 wouldn't b last!!
"He's CHEATIN! cause Im CHEATIN! and He beat ME!" :) "TKI4 PILOT" /XRAY NT1 16' /FUSION X3LCFM / M2c / PROTEK / FUTABA 4PX / SAMURAI
1evo RRR Driver is offline   Reply With Quote
Old 11-02-2011, 03:24 PM   #544
Suspended
Thumbs up
The Ntc3 is last , come on man ..... it's a legend...lol...
bertrandsv87 is offline   Reply With Quote
Old 11-02-2011, 05:00 PM   #545
Ofcourse I will choose V-one R4... I switch from Xray to Kyosho and my lap times improve a lot...(1.5 sec by lap!!!)...I won 2 stages from national championships, and make the TQ an de Best lap of all the tracks of the nats!!!...
But...If you are noob... choose a Shimo used...if you are more experienced...R4 rules!!!...
TomasRC is offline   Reply With Quote
Old 11-02-2011, 05:25 PM   #546
Location: Beneath a rock down by the river. Don't have money for van
Thank you
Step 1 - VZ403HB Hard diff cases.
Step 2 - Aluminum servo horn of your choice.
Step 3 - Assemble?????????
Step 4 - Run it!
( ͡░ ͜ʖ ͡░) https://www.facebook.com/becomeasetupguru/
30Tooth is online now   Reply With Quote
Old 11-02-2011, 09:23 PM   #547
Robert R's Avatar
Test
Chef Robert
Serpent 977
Serpent 811 GT
I have Byron fuel 16, 20, 25 & 30
Robert R is offline   Reply With Quote
Old 11-02-2011, 11:05 PM   #548
MikaR's Avatar
Wow.. congrats! Any setup to share?
http://modelcartuning.simplesite.com/
MikaR is offline   Reply With Quote
Old 11-02-2011, 11:50 PM   #549
I'm not callin you a liar, but I'm willing to bet that there was something def wrong with ur xray if u picked up 1.5sec a lap!!! Thts alot! Thts like D main to the A main! I haven't witnessed those type of gains at our track! Ive heard from X RRR drivers tht the car turns better but it hasn't showed yet in lap times..... But if thts wht the R4 has done for u I would def stick with it.....
Old 11-03-2011, 11:11 AM   #550
Thanks for the help... I'll definitely pick-up those diff parts at the same time with kit.
I'm not a noob but I'm no expert, just getting back into the 1/10 scale game.
Old 11-03-2011, 08:10 PM   #551
Roger's Avatar
Or gaining 4/10th per lap right off the bat with the " Sauce " !!
http://nitrokb.netne.net/profiles/RogerSerafin.html
Roger is offline   Reply With Quote
Old 11-04-2011, 08:54 AM   #552
Jajajjaa... With my NT1 I pick the first place...I swithed from Serpent 720 to NT1...but the Xray allways loose the middle belt teeths...I fixed it with alternative belts... those from zepping...And I started to win...Then a group of the better drivers that had been with Kyosho from a lot of time, RRR, FW05R, etc etc... the told me about the R4...So I told to my parents and they gave to my as a birthday present...I start to run and in the Nats I destroyed the lap record (that I had record with my NT1) and made the TQ and first place again...xD....
I`m very happy (crazy) with this car!!! and the results that I had reached!!!..and it's very sad for me that you had a lot of problems with R4...
So... they only objetive thing that I can say is that the cars is really fast...!!!...I was fast with Xray too (first time that I picked up I got the 1rst place in nats too, and the track lap record)...but R4 is faster....for sure...xD
Here are 3 R4, running... one of those had broke diffs two times...
Old 11-04-2011, 09:26 AM   #553
Setup...Its similar to Shimo's Setup... some a little changes..
Consider that my track has medium-low grip, very dry and a little bit bumpy.
Front/Rear:
Shock oil: 400 kyosho/400 kyosho
Spring: Serpent Red New generation/Serpent Red New Generation
Shock Position: B/E
Caster: Spacer 1mm
Camber: 2║ left-right/ 3║ left-right
Toe: -1.5║ / 3║
Width: 198mm/ 200mm
Downstop: -3 / 2 (measured with tool)
Antiroll: flat / Standar
Tire: Enneti sh37/ Enneti sh40
Tire Diameter: 62mm /63 mm
Chasis Height: 7 / 8
Front Diff Oil: 50% 300.000 Kyosho + 50% 500.000 Dynamite
Rear Diff Oil: 60% 50.000 Kyosho + 40% 125.000 Losi
Note: Not filled to the top...Rear diff feels like 90%... aprox...
Wheel Spacer: 0mm/ 1mm
Upper arm Position: B
Body: Protoform P56-N
Thats the important I think... the others setups are like the Shimo setup...
The car fill a little understeering in the middle and corner exit with gas... I will like to improve that...
Some recomendation┐?...
Regards...xD
Old 11-06-2011, 10:35 AM   #554
GREGORY!'s Avatar
does anyone have the weight of the r4 front and rear diffs?
" kyosho rrr wc-team orion crf "
" serpent 966-mega zx21 EM "
" mugen mbx6-picco p7r evo 2 "
GREGORY! is offline   Reply With Quote
Old 11-06-2011, 04:11 PM   #555
barg's Avatar
Send a message via Yahoo to barg
Anyone know if there is an aftermarket alu servo horn for the steering?
Thanks.
XRAY NT1-2015 Spec | Max Power Engines | KO KIY EX10 | Protoform | Matrix Tires | XRAY X12-16
HEI International | www.hobbyexpress.com.au
www.nswrcrcc.com
barg is offline   Reply With Quote
**NSWRCRCC Inc. - Moorebank On-Road** VenomWorldOrder Australian Racing 11447 11-30-2017 04:03 AM
Kyosho FW-05R Finnitro Nitro On-Road 5443 02-07-2017 11:10 AM
Kyosho V-ONE RRR EVO 2 boy2rc Nitro On-Road 2803 10-04-2014 12:50 PM
Kyosho V One Series Prototype (;) nikoskar Nitro On-Road 78 12-16-2010 04:07 AM
