Capricorn LAB-C01 >
Capricorn LAB-C01
Capricorn LAB-C01
Old 03-06-2012 | 02:47 PM
  #1501
Originally Posted by speed6
Hey DS here is a VID of the track on you tube to have a better idea
http://www.youtube.com/watch?v=w_OEaBQVsyM
Setup sheet attached, kindly note that the front sway bar is the new system with 0.9 bar.
Thanks for your support for making me faster and faster
You don't seems to run a screw on the steering servo saver is it for more flex?
My rear left tire is taking a beating till the plastic in 15 min race.
Would it help to run softer springs overall like red or white springs?
speed6 is offline
Old 03-06-2012 | 03:54 PM
  #1502
DS Motorsport's Avatar
Hey people had the 5 out of 6 championship race.
Was first for like 2/3 of the race and guess bloody what on the last 1:30 min i was leading but my tyres didn't survive much more as car was all over the track, 2nd driver was very tight to my ass and in the last 30sec i couldn't defend as car was uncontrolable due to my rear left tyre almost on plastic.
How am i bloody going to solve this issue when Xrays come in with almost 61mm in the rear and i end up always on plastic
Tyres used Contacts Fronts 37 and Rear 42
Also i have noticed that i lost quite some steering comapared to
Fronts 35 and 40 rears Contact
I would stick with the 35/40 combo, as mentioned by others the harder tire will only slip more causing even more wear.
For 15 minute finals I run 32/37 and I start with a 60/63 and still have enough left. Of course your track could be a lot harder on the tires, over here we mostly have smooth/medium traction tracks which are easy on the tires.
Some things you can do to reduce wheel spin:
-Throttle control, go easier on the throttle.
-Longer first gear, this transfers less torque to the wheels which should reduce the amount of wheel spin.
-Back off the clutch a little bit if you're currently running it at optimal settings.
I would suggest trying these things before you start changing the setup a lot since you mentioned the car is handling well. The changes above can reduce the wheelspin quite a lot without affecting your lap time a lot, or not even affecting it at all. You might even go faster because wheel spin reduces the forward and sideways traction and thus slowing down the car. Our cars will always have a reasonable amount of wheelspin compared to full-size cars but if you are burning to a new set within 15 minutes it's too much.
If you want to change the setup you could try going 50cst softer on the shock oil, should provide some more overall traction without influencing the overall balance too much.
DS Motorsport is offline
Old 03-06-2012 | 07:17 PM
  #1503
2056dennis's Avatar
Default tire sauce machine
where can i get pics of the capricorn tire sauce machine
2056dennis is offline
Old 03-06-2012 | 10:51 PM
  #1504
Will try the gear and since I am running 6 hole shock piston with 1200 shall I bring it down to 1000 or 1100?
speed6 is offline
Old 03-07-2012 | 12:18 PM
  #1505
FREELANCE_RCer's Avatar
Here you go.
FREELANCE_RCer is offline
Old 03-07-2012 | 12:35 PM
  #1506
What do you want to see, or know about the tire sauce machine?.
I would suggest 1000cst.
Old 03-07-2012 | 03:53 PM
  #1507
2056dennis's Avatar
[QUOTE=DS Motorsport;10435648]What do you want to see, or know about the tire sauce machine?.
price of one in the states
Old 03-07-2012 | 05:40 PM
  #1508
[QUOTE=2056dennis;10436432]
aprox. 300.00
michael 1 is offline
Old 03-08-2012 | 09:26 PM
  #1509
Default Reciever box
Hi
Have just bought at c-02 and would like to fit a box for the reciever , any ideas ? Have to say , that i'm new to the nitro cars , have been driving large scale before and we were always having a reciever box
Michael
johnsen-dk is offline
Old 03-10-2012 | 05:19 AM
  #1510
What's the secret to taking out the front diff in the least amount of time?
mrgsr is offline
Old 03-14-2012 | 05:59 PM
  #1511
Changing the diff takes a bit of time, but it's already faster compared to the C01
-Remove the radio tray
-Remove upper arm bulkheads
-Remove front shock tower
-Remove front diff retainers.
It seems like a lot but after you done it a few times you should be able to change the diff within 5 minutes.
Old 03-14-2012 | 06:07 PM
  #1512
Hi DS please check your pm
mrgsr is offline
Old 03-15-2012 | 03:20 AM
  #1513
TMF
I do this way:
- remove upper arm bulkhead screws (2 screws)
- remove shock tower (4 screws)
- remove 3 screws of the radio tray.
Very easy.
TMF is offline
Old 03-16-2012 | 10:37 AM
  #1514
I have a C01 I'm thinking about upgrading to a C02. Is it a minor or major change in performance.
PhatPat is offline
Old 03-17-2012 | 01:26 PM
  #1515
nikoskar's Avatar
There are many things that have been upgrated, upper deck, new front end and much more things that are importants for better perfomance.
nikoskar is offline
