Old 01-23-2012, 08:09 AM   #1351
dj apolaro's Avatar
Originally Posted by speed6 View Post
So you suggest moving in the inner hole on the wheel hubs knuckle and from the inside link to move to the outer side?
If you at the longest position at both ends than this is most likely why you are having the issues you are having. The link at it longest really makes the car very stable and kind of lazy, at least for me. And I like a car that pushes a little bit. I would leave the inner one there and bring the one on the hub to the inside. Start with that first and see how you like it. If it is not enough, than go more in steps. I think putting it at its shortest is too much.
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 01-23-2012, 08:11 AM   #1352
dj apolaro's Avatar
I beleive this was an issue as well since tyres where really low. Will check it out.
I am running sway bar flat blades upfront, now will try the new system with .9
In the CO1 I always used the 2.2 wire bar. I like the steering the bar gave compared to the blades.
I am going to try the .9 and 1.0 the next time I use the sedan to test it. I have been running the blades on the C02 since I was waiting on the new front sway bar system.
DJ Apolaro
Old 01-23-2012, 10:38 AM   #1353
DS Motorsport's Avatar
Tironi's car at the pre-worlds:
P1-RC.com
DS Motorsport is offline   Reply With Quote
Old 01-23-2012, 10:53 AM   #1354
NikoRacing's Avatar
Seems like the Red anodized chassis is the main news!! hahah :-P
NICOLA PEZZOTTI - italian F1 cat. driver - Serpent 747 - HIPEX exhaust system - HOTRACE tyres - SANWA M11X
NikoRacing is offline   Reply With Quote
Old 01-23-2012, 11:55 AM   #1355
dj apolaro's Avatar
Where can we find Pre-World information for results, pic. etc.
DJ
Old 01-23-2012, 12:02 PM   #1356
Pooh2's Avatar
Send a message via MSN to Pooh2
DJ
www.rcblood.com
MUGEN MRX5/CONTACT TIRES/DESOTO RACING/TEAM LOGIC
"Since the Bible and the church are obviously mistaken in telling us where we came from, how can we trust them to tell us where we are going"?
Pooh2 is offline   Reply With Quote
Old 01-23-2012, 02:16 PM   #1357
NikoRacing's Avatar
Apart from the red chassis that is only for eyes and no more... it looks like the rear bulkhear has been drilled with small holes all around the bearing that holds the main shaft. Maybe to have a better dissipation... :-S
Old 01-23-2012, 03:00 PM   #1358
TMF
DJ
http://www.nitrowc2012.com/
TMF is offline   Reply With Quote
Old 01-24-2012, 03:50 PM   #1359
DJ Apolaro
So checked the tyres size and have the following results, kindly keep in mind that we turn clockwise so we have much more turns to the right
Front Left
inner 55.2 outer 56
Front Right
inner 56.50 outer 57
Rear Left
inner 54.7 outer 54.9
Rear Right
inner 57.88 outer 59.2
My rear left seems that really suffered, DJ i also found out that since i didn have 2 sets of the same eccentrics i ended up using the middle upper hole in the rear so should i still shorten the link from the hubs and leave the center eccentrics or should i go for stock as they just arrived
speed6 is offline   Reply With Quote
Old 01-25-2012, 06:17 AM   #1360
Some more news:
P1-RC.com
Old 01-25-2012, 06:20 AM   #1361
Francesco with his car:
First and third on the time sheets.
P1-RC.com
Old 01-25-2012, 06:29 AM   #1362
dj apolaro's Avatar
Front Left
inner 55.2 outer 56
Front Right
Rear Left
Rear Right
Looks like the rear left also has little camber as well. The left rear taking a beating is normal. I usually run a harder tire on the rear left for longer mains. I forgot, are we talking about a CO1 or CO2? Run the same position on the inner and run the shorter position on the hub. See how this works for you.
On another note, how about the Jilles change. I must say the track for the pre-worlds looks pretty easy and motors will play a larger roll. Carrying corner speed will be big. I think this track might also be somewhat local for Jilles. I think he is living over there now, so he will be strong for the Worlds. This is the year for RED I think. It will between Mugen or Capricorn this year for sure. Seems to be a lot of Mugen support there. Based on what little pictures there are. Shame there is not real coverage for the event.
DJ
Old 01-25-2012, 06:39 AM   #1363
DJ
Jilles has a room at the track, practices there pretty much everyday.
Regarding the motors, I hope he gets some proper engines this time, at the euros this was the big thing holding him back.
P1-RC.com
Old 01-25-2012, 07:02 AM   #1364
Gael L's Avatar
DJ
I couldn't agree more. Capricorn have been very active with some impressive Euro signings and will be a serious factor come November.
Surprised Hara isn't in attendance as this is his local track as well and he has been seen doing some testing with the MTX-5 at this track.
Gael L is offline   Reply With Quote
Old 01-26-2012, 12:19 AM   #1365
DJ
It's a C02 thanks
All my reviews. romuald31 Onroad Nitro Engine Zone 35 12-02-2013 08:01 AM
New Capricorn Touring Car romuald31 Nitro On-Road 90 01-25-2010 12:58 AM
V-ONE RRR WC vs. MTX-4 rmdhawaii Nitro On-Road 39 01-17-2010 01:25 PM
Tags
corn
