Serpent 710
Old 07-13-2004 | 09:41 AM
  #13846
markp27's Avatar
Default Re: Re: Re: Re: ceramic bearings
Originally posted by 840918001
Hi,
These bearings are very good.
I use them in my Serpent 710, and never had any problems with them. They work great.
I am sure that the Serpent ceramic bearings are good, but we will have to wait and see if they come in complete kits.
If so, I would still go with the Acer racing bearings.
Do the bearing from Acer run smoother and free'er than those in the kit?
markp27 is offline
Old 07-13-2004 | 11:44 AM
  #13847
teammpp's Avatar
Default Re: Re: Re: Re: Re: ceramic bearings
They will probably be the same when new but Serpent's own bearings are the only ones we ever had trouble with in the wet. The rubber seal purple bearings are total rubbish. Serpent do state not to run them in the wet so I guess places like here, Scandaniavia etc cant run Serpent cars most of the year
It's funny how the Yokomo bearings never got effected with our wet weather racing. The Acer racing bearings, skf, or Boca are brilliant bearings (metal shield) as are the XTM bearings which are slightly cheaper.
teammpp is offline
Old 07-13-2004 | 11:52 AM
  #13848
Yes.
They are more smooth, and run defenitly more free.
The problem with rain and the Serpent stock bearings are new to me.
I run the Acer racing bearings, and a friend of my the stock bearings, and we both race in the rain now and then.
He hasn't had the problems.
840918001 is offline
Old 07-13-2004 | 01:52 PM
  #13849
KevinS's Avatar
Default Re: Re: Re: Re: Re: Re: ceramic bearings
SKF makes miniature ceramic bearings? Where do I buy?
I think a full set of Serpent ceramic bearings will be a lot more expensive than $99. Look at what their regular purple shielded bearings cost. I have never seen a full set of those but when buying in pairs you spend more than $99...
I might give Acer a try.
KevinS is offline
Old 07-13-2004 | 07:05 PM
  #13850
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Maxy Velazco
Originally posted by Marcos.S710
i already submitted to Pamper's and Hughies waiting for reply
Make sure your boy TQs and wins races.
InitialD is offline
Old 07-13-2004 | 07:06 PM
  #13851
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Re: ceramic bearings
Yeah, I'd like to know too... As far as I know, they do not.
InitialD is offline
Old 07-13-2004 | 07:08 PM
  #13852
InitialD's Avatar
Sounds like a good deal with the free shipping. Do you happen to know if the complete 710 kit bearings from Acer includes all bearings in the car like the small steering rack bearings, bearings in the ball diff, Centax and ball diff thrust bearings? Thanks.
InitialD is offline
Old 07-13-2004 | 09:01 PM
  #13853
Marcos.J's Avatar
Super Moderator
Default Re: Re: Re: Re: Re: Re: Re: Re: Maxy Velazco
he will as soon as i can get him to grab the controls!
Marcos.J is offline
Old 07-13-2004 | 10:18 PM
  #13854
markp27's Avatar
I've sent a mail to Acer - I'll let you know when they reply.
markp27 is offline
Old 07-13-2004 | 10:38 PM
  #13855
Ceramic ball-dif is must have I guess.
Yes its cost more, but save your plates many times. You just need to polish the plate everytime you rebuilt.
Ceramic Car(710)-kit from Boca consist 25 pc. Does not include steering crank, ball-bearing in the diff is not ceramic but they put 2pc 2nd spur flange bearing.
GoldFinger is offline
Old 07-13-2004 | 10:49 PM
  #13856
markp27's Avatar
WOW these guys are quick!!!! The 710 kit doesn't include the centax bearings. They didn't say if the kit contains the loose ball bearings for the diff - just checking.
markp27 is offline
Old 07-13-2004 | 10:51 PM
  #13857
markp27's Avatar
Man, these guys are too quick I hardly get my question sent before the reply
No balls provided, only the bearings.
Well, I'll make my order, I think. Looks good to me
markp27 is offline
Old 07-13-2004 | 11:32 PM
  #13858
PSI Racing's Avatar
Do you know if Acer makes ceramic bearings for the centax that you could buy separately?
How about Boca?
PSI Racing is offline
Old 07-14-2004 | 12:19 AM
  #13859
Arun's Avatar
I bought some ceramic diff balls on eBay a couple months ago (10 USD) and I am very pleased with them so far.
Even after not cleaning the diff for seven weeks, the diff still worked smoother than a brand new stock diff! I finally cleaned it last night just for the hell of it.
Arun is offline
Old 07-14-2004 | 12:24 AM
  #13860
InitialD's Avatar
Hi Arun, do you use any kind of lube on the balls in the rear diff?
InitialD is offline
