Serpent 710
#1306
Originally posted by JABRONI
710 offering, Check this site out, ?359.99
http://warrickcustomhobbies.com/insi...dex.php?cat=74
And also....shipping cost, I've seen $45.99 shipping within lower 48 states before for a Serpent kit before.........somehow they have to make the money somewhere.
#1308
Originally posted by ammdrew
no not a chance.. to date no one has put forth anything worthy of switching platforms nor do I see anything in the near future..
I will be in a snake at winternats..
My friend just sold his with Nova Mega for $300......the release of 710 does not help, but because of the 710, lots of ppl would like to take a BIG CUT and sell the 705.
#1309
Just browse thru the I-manual while having lunch..........and realized that the shock's hole position are 4-6 holes now, instead of 1-4 holes.........is that something new on 710 or it was changed since 705 era (while they created the KEY shaft for the shocks)....thanks everyone.
#1310
The adjustable shocks have 2-3-4-5 hole positions.
It used to be 1-2-3-4 holes.
Glenn Cauley
Ottawa, Canada
#1311
Originally posted by fmolzer
I know, I have been staring at that (10) thing too ever since it first showed up..... It's like seing the candy in the store but not being allowed inside....
http://www.mytsn.com/products/downlds.asp?prid=3293
#1316
Step 3.5 The way I see it shows that the rear upper arm(by way of hinge pin) can be moved up/down ,inside/outside with the spacers they have and that the lower arm can be moved up/down Looking interesting more and more
#1317
The rear upper and lower inserts are used to fine-tune rear roll center setting.
The rear upper insert has 4 positions: TopOuter, TopInner, BottomOuter, BottomInner.
The rear lower insert has 2 positions: Top, Bottom.
By setting various combinations of the inserts, you can raise or lower your rear roll center.
When setting the rear upper inserts to an 'outer' position, you must shorten the upper arm length. This will give more camber change during body roll.
The DRS arm (dynamic rear steering) inner pivot point can be altered to match the rear lower insert setting, and will also have a range of adjustment as well.
At the front of the car, you adjust the front roll center setting by moving the upper arm mount up or down. This is done by putting shims under and above the arm mount.
Glenn Cauley
Ottawa, Canada
#1318
Originally posted by Schrijver99
Maybe this can soften your pain:
That was like a double dose of Alkaseltzer on a Sunday morning
Thanx !!!!
#1319
710 gearing is almost identicl to the 705 1st is lower.. second is the same out of the box.. rear ratio is 1.89 on the 710 the 705 was 2.0 but most of us ran the 47/22/17 which gave us a 2.13 rear ratio the new lower 1st gear ratio of 3.53 over the old(15/49) ratio 3.26 brings 1st gear down to 5.42 compared to the 705 at 5.39 results 705 lower 1st gear.. with second gear being a wash on ratio 2.54 for both second gear is 4.67 for the 705 with low ratio 4.54 stock and 4.43 for the 710
what does that mean??
well the 710 out of the box has a lower( or faster accel) first gear than the 705 did with the lower ratio installed, and the 710 should have the same top end as the 705 without the lower ratio conversion.. if your motor does not bog to hard and slow down to fast.. the spread may be too much on lots of tracks, good chance you will be looking for lower second gears.. ubless the motors are pulling a few hundred more revs in there powerbands..... I will try and start with a lower second gear.. just a bit as first will be a welcomed blessing..
the new firat gear is like having a 14 tooth clutch bell on the 705.. for those who have found a way to do that you know how snappy that is..
please correct any math issues..
