Serpent 710
Old 05-11-2004 | 03:43 AM
  #10126
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Deans Charging Plug
Originally posted by Picard
I am running similar setting to yourself, but I have changed to white springs and have been improving lap times.
Cool. Good to know that. I need feedback too and good to know that it works good on white springs. One of these days, I'll give it a go with white springs and solid front !
The question I had was why do you only run 1mm caster, I understood that more caster is effective on bumpy tracks and I am running 5mm. Has this something to do with the solid front?
Interested in your feedback
I use 1 mm caster in the front because with the solid front, you usually get less turn in to corners. Less corner radius. Less caster improves that.
More caster gives you a lot of on power steering coming out of the corner which the car already has with a solid front axle.
InitialD is offline
Old 05-11-2004 | 03:44 AM
  #10127
InitialD's Avatar
Originally posted by Delange
Belgium.
Can you try the border or RCCarinternational? I believe they should have it.
InitialD is offline
Old 05-11-2004 | 03:48 AM
  #10128
BaxterC's Avatar
Originally posted by InitialD
Hey Mr. Hudy, you should have sold that glass car to me. I would have bought 10 from you.
I agree, me to, I would have prefered them in kit form, but I would still have bought them, I LOVE building this car... Hudy, please keep away from that kind of language in this forum, also, STAY AWAY FROM THE BOARDS... remember that even the best bicycle will hurt a kid and break bits if the rider cannot ride... normally one would start off with a bike with training wheels, and then move up to a bike that may be better suited to their ability. The same aplies to RC, you may want a car that is better suited to your ability, remember that the SERPENT out-of-the-box is a race winning car that has all the bells and whissles. the other cars are better suited to a less experienced racer. The cars NEED to be hopped-up to for more competitive and advanced\experienced racer, this makes it attractive to a wider audience, the SERPENT is aimed at the top level racer, but is still able to be raced by the mediocre racer, or less experienced racer (like me) but I dont need training wheels. I can drive, both RC and full size.
Think of it this way... Give a baby a glass, it is as sure to break as I am sitting in front of a PC. But give the same glass (unbroken) to a more experience drinker, the glass is less sure to break, unless there is an accident.
Do I make myself clear?
Once again, Language like that is not appreciated on this forum. keep it to yourself.
BaxterC is offline
Old 05-11-2004 | 03:51 AM
  #10129
InitialD's Avatar
Baxter, you're technically evil with 666 post !
InitialD is offline
  #10130
Picard's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Deans Charging Plug
Yes try the white spring, sparksy was the one that put me onto them
I have not altered the DRS arm and noticed that on your setup you have, did you notice a difference when you first tried this?
Also aggree with your comments the car is easy to drive with the solid and great for my consistency. I am getting a diff on thursday but don't really want to change because I am so happy with the solid
Might get down for a practice session first
Picard is offline
  #10131
KevinS's Avatar
Originally posted by markp27
But with it being a glass car, he probably had to sweep the bits up off the track - not much worth in a load of old broken up glass
It's dangerous too!
Drive through that glass and you may end up with a flat foam!
Possible reasons why Mr Hudy did not like his 710:
- The car is so weak. He would break a part every time he tried to knock a 1/5 scale car off the straight.
- The quality is so low, the chassis was tweaked out of the box. He didn't notice this until after he hammered the brake pins in.
- The car caused his radio to glitch. Whenever the car was coming towards him, he steered to the left but the car would go to the right.
- This car is sooo slow! He wasn't even close to keeping up with his friends T-maxx's and Savage21's at the construction site.
KevinS is offline
Old 05-11-2004 | 03:54 AM
  #10132
InitialD's Avatar
Ummm, I wonder who's that guy in Germany who tries to overtake 1/5th scale lawnmowers at the tracks....
InitialD is offline
Old 05-11-2004 | 03:56 AM
  #10133
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Deans Charging Plug
Ummm, to my untrained hand, I did not notice anything too.
I know what you mean... I too was reluctant to get the front ball diff as I was happy with the solid front. I think on smaller track, I drive better with solid front. It's very stable and does not make the car nervous in my opinion.
InitialD is offline
Old 05-11-2004 | 03:57 AM
  #10134
BaxterC's Avatar
Sounds good :-) You're going to love your car
Did the parts from Serpent arrive yet?
Cheers, Mark.
No not yet...
The dark side speaks freely now...
BaxterC is offline
Old 05-11-2004 | 04:00 AM
  #10135
markp27's Avatar
More like runs into the back of the throught the left kink at the end of the straight - man those things are slow! they should stay on the grass where they belong
markp27 is offline
Old 05-11-2004 | 04:03 AM
  #10136
InitialD's Avatar
InitialD is offline
Old 05-11-2004 | 04:07 AM
  #10137
Picard's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Deans Charging Plug
I will give it a try also
Did your lap times get faster or your cons get better with the ball diff? I am assuming you ran the solid and the ball diff at the same track
Picard is offline
Old 05-11-2004 | 04:11 AM
  #10138
InitialD's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Deans Charging Plug
I did not time the laps but with the solid front, I could drive very agressively around the corners and infields. Felt very nice and comfortable.
I would think you would benefit with the front ball diff if there was a fast sweeping corner.
InitialD is offline
  #10139
BaxterC's Avatar
Originally posted by PSI Racing
Too bad Serpent didn't make his car out of plastic and carbon fiber.
Maybe he wouldn't of had to sweep up all that glass.
I'm glad that my 710 wasn't made out of glass.
I am too, I dont like glass with all that vibration from the engine.
BaxterC is offline
Old 05-11-2004 | 04:19 AM
  #10140
Picard's Avatar
Default Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Re: Deans Charging Pl
Yes that is the reason I am going to try one. Are your races not timed ID? How does you qualifing structure work then?
Picard is offline
