Serpent 710
#9826
Hi Glenn,
Really like the equipment list article - this is for me, as I always forget something. I'm getting better, though! This week I only forgot my crystal! but, I had my spare set This is a big improvment for me
#9827
Re: Re: Re: Re: Re: Re: Re: New Serpent Owner
Originally posted by markp27
Koool! My order is already in for my 705 GTP conversion - I've ordered a Lola shell, too.
Maybe we should all turn up at MACH Heemstede and make, like what D says, an impromptu RCTECH-Serpent Worlds - sounds good to me
Let me know if the weather forecast from 3Hobby.Com was right!
#9828
Re: Centax
Ok, followed Glens notes to the letter - will be keeping an eye on the grease in the thrust bearing from now on Seem ok after build - left the clutch gap at 0.7mm and about 0.1mm end-play. The clutch bell spins for 5 seconds with everthing in place and greased - seems ok
Cheers, Mark.
Cheers, Mark.
The secret is the grease and re-grease it at least once in a race day
#9829
I've got Mugen Super Grease on there - I smeared a coating onto the two bearing carriers (i.e. a blob onto each bearing carrier and then wiped it round until the whole carrier had a coating) and not onto the balls themselves - how much did you put on.
I think last time I used an Assos grease which isn't as sticky as the mugen.
Cheers, Mark.
Cheers, Mark.
#9830
Cheers, Mark.
Cheers, Mark.
#9831
Here's a pic of the smearing - see what you think - I'm already paranoid after one bust thrust bearing
#9832
Looking at it again, if I push the bell in, then it spins more than 5 seconds and if I pull it out (even though the gap is only about 0.1mm or 0.05mm) the bell only spins for about a second.
Cheers, Mark.
Cheers, Mark.
#9834
#9835
Originally posted by cox049
Perfecto! Mark, add that pic link to the FAQ.s the TB is a real issue for Centax beginers so looking at how it's supposed to be greased is going to be useful!
Thanks for the advice
#9837
Problem with thrust bearings. I've done a little studying on this thrust bearing thing and this is most lilkey the issue as I have been asking racers how their clutches are working. The 710 seems to exibit the following condition.
I have been told that the clutch set up properly has a very narrow sweet spot between bog and slip. once the happy spot is found the car leaps off the corner and after it shifts into second at about the 200 ft mark it acts like it shifts again. Its visible! The clutch is slipping as is the propensity with the little clutch setups like the Kawahara and 710. running a heaver spring makes the problem worse. the bell then overheats and literally melts the flyweights causing clutch bell endplay to grow which coupled with the heat cooks the thrust bearing. The solution is to run Glens setup with the Serpent Yellow shoe, heavy spring and weighted flyweights. Or the Red Rulon shoe (they are available) I make with a mugen hard silver spring and weighted flyweights. your thrust bearing issue will go away. My 710 has yet to hit the pavement but some of my friends have been running it for a while.
The 950R seems to do this to if you set it to loose on a high bite track without a high bite shoe. If the flyweights melt the shoe bites the bell at an angle and it cooks itself and throws its guts out on the ground.
Ive gone several races with my Mugen cars using the red shoes and literally ignored the thrust bearings and never had a failure all of last year. So Its not a lube issue its a heat issue.
#9838
#9839
Only with a high bite Red Rulon AR shoe and weighted flyweights.
It wont work with the stock shoe. you could use weighted and non weighted flyweights with it depending on how you like it. The red shoe slips less reducing clutch bell heat. because of this the engagement point needs to be higher to eliminate low speed bog and by the time you get the stock spring adjusted into the window it is almost bottomed in coil bind.
If you don't have the shoe you could use glens setup with the yellow serpent shoe.
I will have a hundred red shoes finished next thursday.
#9840
