Serpent 710
#6541
Originally posted by rodrigo1508
I will keep my r40 for practicing I do not want to pay for parts braking during practice, but Ill keep the 710 for racing
#6542
Originally posted by SupermaxxRich
Soo, so far the new thicker shock tower seems to be stronger "D"? Thats good news. Now we just need the longer rear wishbones and bumper plates and we're set! What bumper plate breakes on the 710? The upper or lower one?
The upper and lower bumper breaks apparently. I broke the lower bumper plate twice (both times hitting steel barriers trying to drive on a new track) and bent the upper bumper plate once in one of those times.
For me, the rear wishbone problem can be solved tentatively by using the longer steel pivot ball or by using shorter rear trackwidth which makes the stock pivot balls go in deeper.
I'm using the stock aluminum pivot balls in the rear and usign smaller rear trackwidth with no problems.
#6543
Originally posted by Profoxcg
who makes those spacers? where can i get them?
#6545
Originally posted by cox049
Hey Rodrigo do the front shock tower mod and you'll save the shocks the next time. It will give room for the shocks to move backwards on the impact.
#6546
Originally posted by B
Is serpent going to come out with revised/ stronger front Knuckles and upper suspension arms?
It seems like that lots of people are breaking those as well.
But seriously, I still have original front upper arms. I'm also still using the same knuckles. I've also used the same pair or knuckles in my 705 (same original one) since it came out as an option for the 705. For me, most of the time the knuckles will pop out of the pivot ball when I clip something. I guess that's the reason why the knuckles do not break. Another guy at our track also kept breaking the original knuckles of the 705 but when he changed to the FC steering blocks (the same ones on the 710), he stopped breaking them. Just that now, the knuckles pop oput of the pivot balls.
As crashed_1 mentioned, my 710 went into the steel fence grills at the high speed sweeper going into a straight and my dogbone just pop out. Nothing else broke.
#6547
Originally posted by InitialD
Cool. In your last pic, you only used plastic spacers. It looks like you used an aluminum and some plastic spacer. Is that correct? Also, it looks like you moved the 5th body post to offset the new front shock tower position.
#6548
Originally posted by crashed_1
Your shunt into the dreaded metal fence of death was pretty hairy that day... Guess what, I had the same accident b4 you came @ exactly the same spot with the same mistake you did...taking the outer line and not making the turn in time... Lost traction and WHAM!!!! Lucky thing nothing broke...
Well the next day at Andalas track was fantastic though... Just that you weren't there to watch !
#6549
That was a very hard one!...
#6550
parts breakage
My opinion:
I'm braking a lot of parts because I'm hitting a lot of things, period. This includes the body which I ripped off a complete fender today...
Now if I ask Proform to make thicker bodies, and serpent to make stronger pieces... what will I end up having?? A nice and strong tank?
I will complaint if a part or component fails prematurely due to normal use, but if I like to go fast and I don't know how, so I crash and brake...
I hope you all understand what I mean this is a fine "race" car
#6551
Actually the shock tower didnt break
#6552
oohhh!! Thanks, didnt read the post completely and since its called front shock tower mod I thought if was to protact the tower. Ill check it out
#6554
What rear track rod?
#6555
Re: parts breakage
My opinion:
My opinion:
Yes, no car is complete free from breaking. And that newer cars usually have a few problems that need ironing out. However, the 710 is prone to breaking in those few areas, you cannot deny it. And no, that does not happen on a number of other cars. My Mugen and kyosho's for that matter, does not have the same problems. I am not bashing serpent here. I am only stating what is true. That aside, the mugen front knuckle is also prone to breaking, but that is pretty much it.
I have received good replies regarding my questions. Thanks very much to a number of invididuals for that.
