Serpent 710
Old 03-17-2004 | 08:16 PM
  #6181
jfc_tech's Avatar
Originally posted by InitialD
Which one is this? The one with the front solid axle setup?
I used 35 shore and 37 shore rear on that setup and it worked well too. No traction roll problems.
I use lowest roll center in the front and slightly higher roll center (UBO / LB) than the stock rear roll center (UTI / LB) with the solid front axle setup.
i use the rear setup UBO/LB...but not with solid rear axle or even the front solid. the shorter arm at the rear.
jfc_tech is offline
Old 03-17-2004 | 08:24 PM
  #6182
InitialD's Avatar
Default Re: Re: Re: Re: Re: GQ tires
Originally posted by GoldFinger
So its "being" wider in trackwidth when using GQ tires.
Thanks bro...
No problems bro. I assume that for the GQ 0 offset front tire on is 0.25 mm wider on one side and the 0 offset rear tires are 0.5 mm wider on one side. I always knew that GQ tires have slightly "wider" offset when compared to the other tires. Perhaps that accounts for their "more" grip.
InitialD is offline
Old 03-17-2004 | 08:27 PM
  #6183
InitialD's Avatar
Which is the same as what I'm using...
InitialD is offline
Old 03-17-2004 | 08:30 PM
  #6184
InitialD's Avatar
Yep GQ is a good tires if u don't mind the edge cracking. its a 2mm offset tires., if i not mistaken...so make sure ye change yer track width b4 running it on spec'd race.
The reason why we are getting GQ +2 mm offset rear tires is because the GQ importer here is bringing them in ! Guess for which car !
InitialD is offline
Old 03-17-2004 | 08:31 PM
  #6185
jfc_tech's Avatar
that shorter arm is really short...in order to get 3.5 or 3deg chamber...the whole thing just touched together. i can't even see the pivot ball anymore..is that correct
jfc_tech is offline
Old 03-17-2004 | 08:32 PM
  #6186
jfc_tech's Avatar
my 1st experience is with GS Vision Pro..
jfc_tech is offline
Old 03-17-2004 | 08:36 PM
  #6187
Default Re: Re: Re: Re: Re: Re: GQ tires
No Dee. its per wheel !! amazing yaa.!
What I do, I set my trackwidth using GQ, and if I am using EVI rims, I put wheel spacer accordingly.
Thanks for describing for me.
"Feel more grip" yes.. coz they wear in faster rate.
GoldFinger is offline
Old 03-17-2004 | 08:41 PM
  #6188
rodrigo1508's Avatar
anyone here has the clutch mod? does it really make a bifg difference?, I ask because I finally fired up my engine but It took forever to go, I had to rev it a lot
rodrigo1508 is offline
Old 03-17-2004 | 09:26 PM
  #6189
how do you guys tighten the coupler that goes over the spring?? It has two slots in it opposite from each other? I have no clue how to tighten that turd? Please Help, thanks.
SupermaxxRich is offline
Old 03-17-2004 | 09:30 PM
  #6190
Just gained a little more finger strength and twisted it with my finger Is this what you guys are doing?
Old 03-17-2004 | 09:33 PM
  #6191
So, with the clutch shoe mod, I'm a little confused. After you cut down all three shoes a little you don't put the shoes on the pegs you put them inbetween??? At least thats what understood from the pictures?? Let me know, thanks.
Old 03-17-2004 | 09:37 PM
  #6192
How do you adjust that spring nut after the car is all together??
Old 03-17-2004 | 09:50 PM
  #6193
InitialD's Avatar
You can buy the Mugen tool which is expensive for that purpose or you can get this new tool from Serpent. Cheaper as it is made of plastic versus aluminum.
It is actually the top right one. You can also use it to tighten the pressure nipple on the tank with the other end of the tool.
InitialD is offline
Old 03-17-2004 | 09:53 PM
  #6194
InitialD's Avatar
Yes, put the flyweights in between the metal post.
InitialD is offline
Old 03-17-2004 | 09:56 PM
  #6195
InitialD's Avatar
How much is your clutchbell to clutch shoe spacing? Are you at 0.7 mm as per the manual? Loosen the pre-tension spring nut until you get decent engagement.
If you want to get more punch out of the clutch, do the flyweight mod. You may want to use 0.4 mm or 0.5 mm as the clutchbell to clutch shoe spacing.
InitialD is offline
