Old 03-17-2004, 09:05 AM   #6166
BaxterC's Avatar
10 Sets... I also ordered... I also hope they are good... but they look sweet... look at a black body with a neon orange (not brown ) stripe on the side with 710 in it... with a chrome chinese 'air' symbol on the roof with a green haze.... this is copyright guys... when I visit your country and see this... I will know you were on the forum andmake sure you drive like th car looks....
BaxterC is offline   Reply With Quote
Old 03-17-2004, 04:05 PM   #6167
Sow&Steady's Avatar
Originally posted by cyba888
Sow&Steady
What engine do you have under your hood? The one in your avatar pic
Oh! Its an Quantum2 Jet engine of course .
Sow&Steady is offline   Reply With Quote
Old 03-17-2004, 04:13 PM   #6168
Sow&Steady's Avatar
Default Re: GQ tires
Originally posted by cox049
I hope they're good, I ordered 10 sets. The price is good $200 shipping included, 5 sets 37 shore and 5 sets 40shore
If anyone is interested I can hook u up
I used to use them a lot. They provide very good traction in general but you need to be careful with the long mains ... they get more and more grippy as they get warmer.
If you've set your car when they're colder then you'll most likely traction roll by the time you're midway through the main.
I got caught out in two races and have decided to switch over ... need consistency man!
Old 03-17-2004, 08:10 PM   #6169
cyba888's Avatar
What is traction roll?
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 03-17-2004, 08:18 PM   #6170
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
Yep GQ is a good tires if u don't mind the edge cracking. its a 2mm offset tires., if i not mistaken...so make sure ye change yer track width b4 running it on spec'd race.
traction roll is when u have too much grip and car can roll on its top in the corner...happen so many times to me
ending up broken rear shock tower
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 03-17-2004, 08:23 PM   #6171
Super Moderator
Marcos.J's Avatar
Trader Rating: 182 (100%+)
maybe initiald can answer!
Old 03-17-2004, 08:23 PM   #6172
cox049's Avatar
Flip over
It's better to say "I had a lot of traction roll" than I flipped over all day
cox049 is offline   Reply With Quote
Old 03-17-2004, 08:26 PM   #6173
rjl
rjl's Avatar
Limit your droop.
rjl is offline   Reply With Quote
Old 03-17-2004, 08:27 PM   #6174
cyba888's Avatar
Flip over
Im the master at traction roll! No one can beat me on that one!
Futaba 4PX
Old 03-17-2004, 08:29 PM   #6175
jfc_tech's Avatar
Originally posted by rjl
Limit your droop.
I just followed InitialD setup...and walla!! never traction roll again even after i used overgrip 35shores.
i found out the higher roll center do help my driving...interesting 710...love the variability!
Old 03-17-2004, 08:57 PM   #6176
Default Re: Re: GQ tires
There is a good info/explaining how to deciding tire shore for the long main from Art Carbonell :
When I just start out, if my car turns perfectly, I know I'm in trouble, because when the tires warm up,I know I'll have too much steering.
TIRE SELECTION from Art Carbonell
Just Info :
For GQ-MTCS (0 offset) tires compares to Ellegy EVI rim(stock green)
in Front EVI = GQ + 0.5
in Rear EVI = GQ + 1
GoldFinger is offline   Reply With Quote
Old 03-17-2004, 09:00 PM   #6177
InitialD's Avatar
Default Re: Re: Re: GQ tires
Are you saying that the GQ tires are wider or narrower?
Old 03-17-2004, 09:07 PM   #6178
InitialD's Avatar
Which one is this? The one with the front solid axle setup?
I used 35 shore and 37 shore rear on that setup and it worked well too. No traction roll problems.
I use lowest roll center in the front and slightly higher roll center (UBO / LB) than the stock rear roll center (UTI / LB) with the solid front axle setup.
Old 03-17-2004, 09:14 PM   #6179
cyba888's Avatar
Thats good to know...I raised my front roll center as well so hopefuly I can test it out this weekend too. The rear roll center looks too difficult to play with so im going to just leave it as is
Futaba 4PX
Old 03-17-2004, 09:15 PM   #6180
Default Re: Re: Re: Re: GQ tires
Thank God, Im mixed up
in Front GQ = EVI + 0.5
in Rear GQ = EVI + 1
So its "being" wider in trackwidth when using GQ tires.
Thanks bro...
If you using a Yokomo setting wheel to measure the trackwidth precisely, GQ is the closest.
