Serpent 710
#5251
#5253
Originally posted by markp27
But I thought for the thrust bearings, graphite grease was recomended?
Likewise, for the diff balls, I smear a very thin coat of the same grease on them before assembly. Still no gritty feeling after all this while of running.
#5256
Originally posted by SupermaxxRich
IS this new shock tower available? Is it suppost to be any stronger than the original?
What is the is graphite grease and where can I purchase? Thanks.
D, what do you use for the drive shafts?
#5257
#5259
I use the Tamiya graphite grease. But maybe as D suggests, you can simply use the Mugen/AE grease.
#5260
So is it a grease or more of a powder?
Be careful when putting places near bearings though. I found that when I put the graphite on the middle shaft and 2 speed layshaft, it went into the 6x13x5 bearing and made it gritty !
#5264
Originally posted by InitialD
Ideally, you would want to use dry graphite grease on all moving parts except the thrust bearings. For thrust bearing and the diff balls, I use the Mugen Super Grease. For the middle shaft and the 2 speed layshaft, I dab a drop of silicone shock oil where the bearing rubs on the shafts.
I've tried using silicone shock oil with success. Now I'm trying out the Serpent Bearing Lube 1682 as per the mytsn tip.
Do you have a link to the tip on mytsn?
Cheers, Mark.
#5265
http://www.mytsn.com/publ/publ.asp?pid=9215
Have you received them yet?
