Serpent 710
#3466
Originally posted by Pit-racer
Pics as promised
Pics as promised
The body after 45minutes A main..hehehhe rough day
#3467
Originally posted by jfc_tech
way too cool man...nice paint job there...this is mine if can attached here....the front hole a bit too high on the roof but i still can't figure out where to make the correct hole...
I thought I read it from ammdrew that the lower main cooling hole gives better stability and rigidness to the bodyshell.
#3468
Guest
Re: Re: Re: Suitable Synthesized Receivers
Originally posted by Diesel Racer
Thanks for the info FTSPEEDWAY, am I right in thinking that you can use the Synthesized receiver without the tx module?
#3469
Originally posted by InitialD
Team Serpent USA cuts a low as possible hole in the front screen as the main cooling hole. A second small hole is cut for refueling.
ok...anyone got a picture for this...right in front of the windscreen so i can copy it. i don't wish to mess hole..too expensive to cover it back...if i can
#3470
#3471
Have you seen my reply to your post? At the bottom of page 114.
thanks D.
#3472
Can anyone here comment on the big wing effect of the Alfa 2.1? I can feel that it's like a parachute vs using the stratus 1. Thanks.
#3473
i got it thanks...so its ok to have a hole on the rooftoop. some says affecte the aerodynamic of the body...but my BIGGER hole also on the top...still no difference to me...hehehhe
In my opinion, you will really feel the aerodynamics of the bodyshell when you drive the car at high speed tracks. Else if it's a small track layout (like it will be in Kuching), you will probably not feel the aerodynamic differences. My 2 cents.
#3474
One of these days, I'll give another go with the Alfa 2.1 since it was given FOC at the SAC race.
#3475
#3476
TitaniumR, that's what I noticed too ! Not just the looks but when I tried a friend's Protoform Alfa 2.1 when I did not have a bodyshell on my 710, the car felt REALLY stable and it was kinda difficult to make the car take corners. In short, it was understeering. First impressions, I did not like it. Perhaps my friend needs to trim the rear wings a little more. I put on the Stratus 2.1 and I was happy. Stable and at the same time I had steering.
#3477
That's my preference for this body though so you'll need to try it at your own rick.
#3478
Originally posted by Sow&Steady
I think you followed the main cutting lines on the wing. I suggest you use the smaller line for cutting ... it's marked as "ROAR" if you look closely at the sides of the wing. Follow this line through around the back too.
ok, here my 710 kit picture after 14 tanks (RS5 STS=6 tanks, Nova Max P5=8 tanks run-in)
