Serpent 710
Originally posted by ntc3freak
thanks d.but wait for somebody to buy my car 1st
Originally posted by Greg M
I'm 10 minutes from my track too.
Re: Re: 710 DRS mod?
Originally posted by InitialD
Interesting... Does the DRS arm hit the chassis when the arms drop down? I take it the rear bottom pivot pin is longer? From which car is the bottom rear pivot pin from?
I rarely need to change the DRS but I know when you have to do it, it can be a PITA. When I have to change it (when changing the lower RC mount from bottom to top or top to bottom or when the DRS arms snaps...), I usually take the entire rear portion out by unscrewing all the Phillips screws under the chassis for the rear section. Detach the side CF stiffeners and the whole rear pops off. Then from the underside, it is easier to work on the DRS arms and the spacers.
But I think living in NZ plus living about 10 minutes away from the track is even more bliss !
Originally posted by Sow&Steady
I'm no longer in NZ but I'm definitely, exactly, 10 mins from the track!
Originally posted by Brett.w
When were you in NZ? if your comming back let me know!
Yes, I do plan to go for a visit one day ... will let you know if it happens.
Anyone install the new Spektrum 2.4 Ghz receiver in the 710 ?
I usually slap a balloon over my receivers but these new Spektrum receivers have a led indicator and a BINDING set button.
yes I have .Love it so far.
Do you protect it with a baloon ?
How about the FAIL SAFE is it working ? I can't get mine to throw the brakes onwhen loss of signal.
I redid the binding process and the fail safe is OK now.
No I don't cause when its wet I don't run. I set the failsafe to for neutral position. I don't like it to engauge the brakes !!!!! But thats me.
droop
can i adjust front droop on the 710???after reading the manual,i dun see any droop screw on the front arms.correct me if i am wrong
Re: droop
The front bumper with the 3 x 8mm grub / set screw (H11) is shown at the top on page 6 of the 710 manual (Step 1.7).
Anyway, there's a review of it I wrote in the Contents section at 3Hobby.
Re: Re: droop
Yes you can. Look at page 5 of the 710 setup booklet. Serpent calls it downstop. You adjust the grub / set screw located on the upper front bumper.
thanks d.i will look into the manual a little later on.just imagining of having the car
