Serpent 710
Re: Re: Re: Clutch behavior
Originally posted by clmbia45
I'll bet that Mark has this in his bible: Initial D and I discussed the modification of the shoes which allows them to float freely and they reliably engage and after a year, am running without problems. Initial D posted some grat pics with directions: worth the trouble to find!
jack
jack
Thanks for everyones help.
Bruce
jack
jack
But, somehow in particular corner it mades clutch disenggage not properly. Its like low-needle is too lean but its not.
I am not 100% sure, but after back to the stock one (flyweight) the sympton is gone.
Re: Clutch behavior
Originally posted by slawsonb
I hope someone can help me understand proper clutch adjustment and expected behavior. I have read the FAQ and everything on proper clutch adjustment but it doesn't seem to behave right.
When the clutch is cold it wont engage at all or just slightly. As it gets hot it starts working better. After about 3 minutes of hard clutch use it finally seems to be grippy enough or somethings so hard hitting that the car may try to spin out.
I have taken the clutch apart several times and re shimmed. I am currently about .5mm play. The only thing that gets the car to move at all is loosening the spring nut so it can engage earlier.
The initail slipping and such wouldn't be too bad on a large track but my local track is very small with many tight turns that have me on and off the throttle continuously.
I am a newbie to on-road nitro but have lots of off road experience. Is the centax 3 clutch supposed to act like is described? Any suggestions would be greatly appreciated.
I find the push-pull method prone to error - sometimes large.
Here's what I do:
In step 8.6 place as many shims as you have on the thrustbearing carrier and fit it as shown in step 8.6 as if you were going to use the push-pull method.
Now try pushing and pulling the clutch bell - if there is any movement, add some more shims to the thrustbearing carrier.
Once you have no push-pull movement anymore, remove a 0.1mm shim. Remount the clutch bell and check for push-pull movemnet. Continue to remove 0.1mm shims until there is a slight movement.
Once, you have some movement you can remove 0.6mm worth of shims and this will give you a clutch gap of between 0.6 and 0.7.mm - which should be perfect for most situations.
Now move onto step 8.7 and again add as many end-play shims as you have. Mount the clutch bell with the metal shielded bearings and check for end-play. If there is end-play....add more shims.
Once you have no end-play, start to remove the 0.1mm shims. As soon as you feel a bit of end play, remove one more 0.1mm shim. This will give you just the right amount of end-play.
After running your car - if you feel you want a smaller or bigger clutch gap, simply add (for smaller clutch gap) or remove (for bigger clutch gap) a 0.1mm shim from the thrustbearing carrier. NOTE! You must compensate for the new clutch gap by adding (if you remove a thrustbearing shim) or removing (if you added a thrustbearing shim) one of the end-play shims - the shim must be the same thickness as the added or removed thrustbearing shim.
Hope that's clear.
Cheers, Mark.
jack
jack
Any of you boys got any tips/improvments which are mentioned in the FAQ? PM me if you want them included.
Cheers, Mark.
Check list
Mark,
just to keep dreaming about a future trip in florida with luggage full of my favorite toys, i would really enjoy to have your detailed list of stuffs for the winter nats. you will be certainly overweighted at the flight checkin...
Re: Check list
Originally posted by pelos
Mark,
Mark,
Re: Check list
Hmm, lets see now - 1x PC, 1x VRC
Well, I'll certainly have my two 710s with me, both kitted out with diffs front and rear - I don't like the idea of a one-way on the Ft Myers track.
I'm currently preparing 3 Mazda 6 body shells + the one I already have.
I'll be taking a minimal number of tyres, as it'll be cheaper for me to get them at the track due to the exchange rates.
I'm taking a JP-Fx03 and am collecting a Mega at the track.
Yeah, there's my tools, spares, charger, setup gear, stand, hudy board, starter *oooof* heavy!! My radio.
I'll be putting as much heavy stuff in my laptop bag to get it up to the allowd 10kg and the rest in my suitcase.
Well, back to the shell painting.
Cheers, Mark.
Cheers, Mark.
Re: Re: Check list
Originally posted by markp27
*faint* *thud*
*faint* *thud*
Re: Re: Check list
Cheers, Mark.
Cheers, Mark.
Which brand you think?
Post some pics of the shells when you're finished!
Did you managed the 40MHz issue?
Will you do the roar at the track?
In bocca al lupo!!!
Fabio
Re: Re: Re: Check list
Good to find tyres at cheap price
In bocca al lupo!!!
Cheers, Mark.
Re: Re: Check list
Originally posted by crashed_1
careful there, the 'Prophet' might call you a 'wooz' for using diffs.
Re: Re: Check list
[B]Hmm, lets see now - 1x PC, 1x VRC
Cheers, Mark.
Cheers, Mark.
Re: Re: Re: Re: Check list
Ahem, did I say Diffs I meant hardcore one-ways *cough*
Originally posted by Sow&Steady
You forgot the the digital camera and an FTP connection old man!
