Serpent 710
Originally posted by Darth Vader
I'll try to narrow the front end a bit to about 198mm and see how it goes. That means another 10times removing and fitting the front wheels...
May try the shims too. The Speedmind wheels I'm using are very close to touching the steering rod ends.
So when you set the trackwidth to 198 mm, when using these spacers, the trackwidth will come to around 199 or 200 mm.
Plan to run in engine tonight...
Read the WOT run in methods in the FAQ. Will try them...
Thanks again guys.
Yup, I set the track width with the wheels on and measure from outer edge of tyres.
Hey, maybe my car came with the Precioussss dogbones...
Wishful thinking I know, but the previous owner put cable ties around the bones to prevent them going missing in case they fall out. Maybe he did it coz they're Precioussss...
I've actually got some 0.5mm sheet aluminium at home. Maybe I'll use that instead of the lexan.
Thanks D. I forgot to mention, I bought a new Novarossi pipe from LHS. But wouldn't mind trying out your shark pipe later on just for comparison. If it's still available...
Let me run the car and get used to it first.
Wishful thinking I know, but the previous owner put cable ties around the bones to prevent them going missing in case they fall out. Maybe he did it coz they're Precioussss...I've actually got some 0.5mm sheet aluminium at home. Maybe I'll use that instead of the lexan.
If they are a bronze colour, then they are the real deal
Regarding your disc wheels, you could drill a couple of holes in them, so you have access to the pivot balls.
Another advantage of using shims to set your track width, is you don't alter the front toe. You can quickyl change a 1mm shim for a 0.5 mm shim, in order to try out a narrower track width. If you changed the track width via the pivot balls, it would also changed the front toe.
Cheers, Mark.
Cheers, Mark.
Originally posted by InitialD
Well, depending on which side you were Mark... You do realise that the baddies in the movie didn't get a good ending didn't you?...
Nope, not bronze. The normal blackish colour....
D,
I think it's in-line pipe. How do you tell? It doesn't have a silicon tube joint. Just a rubber gasket between the manifold and muffler with 3 little springs holding them together. Is that good...?
Yes, the shims would negate the need to adjust the toe everytime track width is changed. Shims it is then...
Drill the wheels...?
Errr... maybe not. I like them the way they are... even thought I have to remove them a lot...
D,
Look at what the Winternats did to you !
