Old 03-05-2004, 07:34 AM   #5296
clmbia45's Avatar
Lightbulb
Originally posted by InitialD
Ideally, you would want to use dry graphite grease on all moving parts except the thrust bearings. For thrust bearing and the diff balls, I use the Mugen Super Grease. For the middle shaft and the 2 speed layshaft, I dab a drop of silicone shock oil where the bearing rubs on the shafts.
I've tried using silicone shock oil with success. Now I'm trying out the Serpent Bearing Lube 1682 as per the mytsn tip.
Oil is oily- I've never found one that repelled dust yet.
The Pro bicycle riders have a great interest in drive train friction and dust: many use a product such as Finish Line Teflon-Plus to lubricate the chain. Dries to non-oily, dry surface and is said by the local Pro to last 100 miles in competition. I have used it on my dogbones, out drives, etc. for 2 years now and note substantially less wear. It sprays on through a small plastic tube and you can easily apply it between heats. I also put it on all suspension point. No plastic damage, though you can see the teflon residue.
clmbia45 is offline   Reply With Quote
Old 03-05-2004, 07:42 AM   #5297
clmbia45's Avatar
It's pretty decent as it's made of aluminum. Some say it is as good as the Hudy if not better. But for the toe in / out, you still need one of Hudy's "rulers".
"C22305
This is the ultimate setup tool for serious racers. Adjust front toe, front castor, front camber, rear toe-in, rear kick-up and rear camber all at the same time, also adjust steering angle accurately, works on all standard size 1/10 touring sedan. Anodized blue alloy with clear toe indicator bar,"....
Mine came with "the clear toe indicator bar", Hudy like ruler. The set is excellent, as is their Laser tweak station.
Old 03-05-2004, 08:10 AM   #5298
cyba888's Avatar
Pyramid,
I did the shocked mod you mentioned in your tips and tricks section. It seems like it has much more play and after the thick washer on the bottom its much straighter. Just as strong and sturdy like you mentioned. Thanks for the tip lets just hope it holds up well
2014 and 2015 BD7 Black Series, Yokomo RPX ESC- Yokomo 4.5T Motor
Yokomo B-MAX4 III Factory Team Kit, Muchmore ESC- LRP 6.5T Motor
Mugen MBX7R Eco- 2200 KV Motor
Futaba 4PX
cyba888 is offline   Reply With Quote
Old 03-05-2004, 08:11 AM   #5299
Send a message via AIM to Profoxcg
Default Bearing Oil as a replacement for Graphite grease
So according to this the bearin oil #1682 can be used all around the car where you would use the graphite grease?
(anything metal to metal?) and ( the suspension ball pivots)
Profoxcg is offline   Reply With Quote
Old 03-05-2004, 08:51 AM   #5300
I read the article on servicing the bearings. They mention cleaning with motor spray? what is this spray where can I find it?
thanks
Old 03-05-2004, 08:53 AM   #5301
markp27's Avatar
Send a message via ICQ to markp27
thanks
This is a degreasing spray which you should be able to find at any car parts shop.
Cheers, Mark.
markp27 is offline   Reply With Quote
Old 03-05-2004, 09:56 AM   #5302
Trader Rating: 16 (100%+)
Originally posted by Cyba888
What do you guys think of the Integy setup tool? http://integy.automated-shops.com/c...-42104473475.4e
As much as I like that...(because I have one) that setup station are NO LONGER working with the 710 because the rear uprights (the top pivot ball area that you will adjust your rear camber)of the 710 sit up HIGH and the Integy setup block DOES NOT have the opening for you to adjust the upper pivot balls thru the setup block...so you can only use the L-shape stock allen wrentch to setup your camber or you setup the camber with the setup block.
And somehow....HUDY one has a circle opening for you to adjust the 710 even thought that HUDY setup station is out almost 5 years already....
I bet Serpent designed the 710 rear uprights for some reason that only HUDY setup will work.
Old 03-05-2004, 10:01 AM   #5303
Send a message via AIM to kreidel
Right...thats logical, build a car around a setup station!
kreidel is offline   Reply With Quote
Old 03-05-2004, 10:02 AM   #5304
Originally posted by cyba888
Are you sure you need the Hudy ruler? It says it can adjust toe in /out
Integy one DOES come with that clear TOE IN/OUT ruler as well....but I think if you want to buy a new one, buy the HUDY because the rear block of the Integy will not allow you to adjust your rear camber on 710.
Old 03-05-2004, 10:04 AM   #5305
crashed_1's Avatar
Originally posted by markp27
This is why we didn't spot him in that picture the other day - we should have looked for a woman who is dressed up as a man
But he has revealed himself to the forum...just give a wild guess...
*clue #2*
the person close to a serpent.
crashed_1 is offline   Reply With Quote
Old 03-05-2004, 10:05 AM   #5306
cyba888's Avatar
Man that sucks
Futaba 4PX
Old 03-05-2004, 10:07 AM   #5307
Arun's Avatar
I believe that the extra hole on the HUDY station was originally put there due to the yokomo gt4 rear upright design, which is virtually the same as the 710's.
http://nexusracing.com
Arun is offline   Reply With Quote
Old 03-05-2004, 10:07 AM   #5308
Might want to check with Rookie Solara. I remember seeing pictures of his cars with the Integy setup and I thought I remember him mentioning that you still need the Hudy ruler for the toe in / out. I may be wrong...
Master D...........GOOD MEMORY....wow, what is that...? P4 with 4.0 Ghz in your head? ....just 1 more time, it is a GOOD setup station, but if you are planning to buy a new one, HUDY will fit 710 better cause Integy one are UNIVERSAL, just not for S710.
Old 03-05-2004, 10:10 AM   #5309
cyba888's Avatar
Hey Solara,
Do you have a side view pic of that setup board? That thing looks too sweet. The Hudy ones seems to crack at the some areas near the bolts. Maybe I can drill a hole to accomodate the camber adjustment on the 710?
Futaba 4PX
Old 03-05-2004, 10:11 AM   #5310
Yes, the first time I spot the 710 rear uprigth, the image is "YOKOMO GT-4" immediately.....
If Hudy did that extra opening for the YOKOMO customer........then they deserve to make more money cause they can use that against the aftermarket work station on S710....
As for me....I borrowed the HUDY one from my friend and if I don't have that HUDY one on my hand, I will still use the Integy one, but just using those stock L-shape black allen wrench instead...just not as comfortable as the regular hex wrench and no that professsional, no big deal.
