Serpent 710
Old 02-16-2005 | 07:31 AM
  #20056
jag's Avatar
jag
Originally posted by InitialD
What do you mean by a "early version" of the ZX12?
It has the "MS" on the head. I think it came from Paolo's collection from the World Championship. Just my guess.
jag is offline
Old 02-16-2005 | 07:33 AM
  #20057
InitialD's Avatar
Oh ok...
InitialD is offline
Old 02-16-2005 | 07:48 AM
  #20058
Did the Serpent drivers use any of the aluminum parts on their cars? Front sway bar levers, upper front arm mounts, etc.?
RoyU is offline
Old 02-16-2005 | 07:51 AM
  #20059
jag's Avatar
jag
Yes, some did use sway bar levers, upper brackets, "X" brace, engine mount, mid shaft bracket, etc...
jag is offline
Old 02-16-2005 | 07:52 AM
  #20060
markp27's Avatar
At the Winternats they were standard kit parts apart from the longer servo saver - I didn't check to see if the middle bearing bracket or radio plate X brace were alu.
markp27 is offline
Old 02-16-2005 | 08:00 AM
  #20061
fmolzer's Avatar
I saw quite a few cars in the snake pit that use the upper front A-arm king pin mounts in Alu. It looks fast...
fmolzer is offline
Old 02-16-2005 | 08:03 AM
  #20062
jag's Avatar
jag
I saw so many cars I can't remember who's car had what parts but I'm pretty sure they were using the motor mounts and mid-shaft brackets. I saw Paolo's car at the state race and he had the orange upper brackets.
jag is offline
Old 02-16-2005 | 08:21 AM
  #20063
markp27's Avatar
I only really saw Rene's and Michael's cars up close - Mr Fmolzer and myself almost managed to swap MS's car for Fmolzer's own Unfortunately MS realised just as we thought we'd pulled it off
markp27 is offline
Old 02-16-2005 | 08:32 AM
  #20064
jag's Avatar
jag
I don't know why he would care. He could have run a 13.0 with my car.
Was he running a front one-way?
jag is offline
Old 02-16-2005 | 08:38 AM
  #20065
markp27's Avatar
He may not have, but we did Although I think his car would have been undriveable for me.
He was using a front one-way, which was quite nice to drive, actually, but he had set his rear diff to almost solid - for me, even only slightly tight and the car fish-tailed all over the place.
markp27 is offline
Old 02-16-2005 | 08:43 AM
  #20066
jag's Avatar
jag
Maybe you had a lot more power than him.
Were you using the same shore tire?
jag is offline
Old 02-16-2005 | 08:48 AM
  #20067
markp27's Avatar
Yep, must have been the uncontrollable power of the JP
Yeah, he was also using 40 shore....basically he was driving his 1:10th like a 1:8th - add to this his skill level and the answer is clear I suck!
markp27 is offline
Old 02-16-2005 | 08:51 AM
  #20068
InitialD's Avatar
Precisely... I thought the same way too. No way one could drive with the rear diff so tight ! But these guys manage to TQ with those setups. Perhaps it's the way they drive.
InitialD is offline
Old 02-16-2005 | 08:54 AM
  #20069
markp27's Avatar
He said he just hits the throttle coming out of the corner and the car goes where he wants it to - divine intervention if you ask me
markp27 is offline
Old 02-16-2005 | 09:01 AM
  #20070
InitialD's Avatar
Perhaps we all had the false RING...
InitialD is offline
