Serpent 710
Originally posted by InitialD
BTW, it takes one cheapskate to know the other. And I think you would agree that cheapskateness
is paramount to RC survival.
I'm the sort of guy who makes his own belt tensioners after seeing the Kyosho price.
It's not the price, so much, as the insult.
Ahuh !
I'll go back and check the OD of the clutch bell.
Ahuh !
But anyway, why don't you change the clutch completely to the Centax 3? That would eliminate the problem since you will use the Centax 3 flywheel and all their internals. Just make sure your engine mounting height is 14.5 mm with a 4 mm chassis.
Or better still change the car to a 710?
Originally posted by rangulo
Does anyone know the Michael Salven Worlds setup or where to find it.. Is it the same as Mark Green.
But Mark Green did. It's not with a front solid but with a hard front diff.
http://www.mytsn.com/setups/setup.asp?sid=2759
You "think" too hard.
I'm just trying to "think different".
Now, I just took a couple of measurements from the Mugen clutch:
The distance from the rear of the flywheel to the rear of the 2nd gear pinion is 19.1mm.
Clutch bell diameter is 29mm
Flywheel is 33mm
Engine mounts are 14mm
Originally posted by jag
So how do you replace those pins? It looks like a real pain in the but.
yo i got bad news because of college tuition i have to try to sell my serpent 710 barely used
link to it being sold
I thought you sold it a long time ago.
Flywheel is 33mm
Flywheel is 33mm
...would you
If you want to get really hobbyistic. Take a alu block about 10mm high, drill a 3.5mm hole all the way through and then takr a countersink and make a dip in th top so the dogbone has good support. This block is placed on a good heavy vice with slightly open jaws. Hammer away!
Once the pin is flush with the ball you'll need a pin that is slightly smaller than 3mm to push it out. I think you'll find stuff like that in the hardware store. One of these pins to push headless nails into wood work well.
Originally posted by Picard
Well if someone had bought a 710, like sparksy and I told him too then you would not need to fit a 710 clutch onto a mugen..
...would you
...would you
I'm far to miffed to reply to that blatent troll.
Somebody, please ask Picard how he broke his rear shocktower.
Well, look what the cat dragged in fella's . . . . .
As I was leading the race and pulling away from Taylor Racing, he decided to use me as brakes at the end of the straight, end result broken shock tower
It is not my fault if I am too fast for you
maybe I should bolt in a kit pullstart engine to give you a chance.
