Serpent 710
#1951
Originally posted by InitialD
So Julius, you have this problem as well for your steering linkage using Sanwa servos? How do you solve it? By setting Your Tx EPA?
I think anywhere within 10 points is not a problem.
Just experiment with the arm angle a bit.
#1952
Originally posted by Julius
I set the link and arm at 90 degrees and the left/right steering is very close.
#1953
You have picture yes???
#1954
I think that is not possible with the suggested link length of 44.5 mm. What length are you using?
#1955
Originally posted by crashed_1
If u r using Futaba 9451 try 42mm...with horn @ 90º.
#1956
I don't think that length is possible with the stock ball cups and rod...
#1957
We'll look into this issue and see if we can improve it for future kits. Please provide info on any mod you made.
#1958
Try it...it worked on mine. Want visual proof too?....
#1959
Below is some of my 710 picture after about 2 hours driving (1 gallon). When you watch my pipe and bumper, you will realize that Im serious about having some T-boned and couple of airshow.
Please look closer to the DRS picture, that happen when I mount it on highest position. Even in normal/lower position that still can happen, when your rear ball got tweaked after hard impact on the rear wheel.
One more thing, the car weight is 1670 with personal transponder.
#1960
Receiver Side
#1961
Scrubbed DRS arm
#1962
Top View
#1963
Back View
#1964
Front Bumper View.
Check the tweaked lower bumper plate, it happen before long 45min A main. Still holds very well.
#1965
Bottom view.
Im showing what the chassis is made for...
