Serpent 710
Old 11-03-2004 | 09:31 AM
  #18406
Sow&Steady's Avatar
Originally posted by Data
well, the top three posters account for about 44.3% of the posts. an impressive effort, if the contents of the posts does not matter.
I know you're right but I hate to admit it that you're right so I'll just twist the matrix. Standby ...
... wait a minute, this is a 710 forum.
Data! What's the screen saying about the matrix! Get us back!
by the way, good job on 3hobby, hope it does not turn into a mini mytsn, we have that already.
Thanks, a lot of work but a lot of fun in these cold winter nights!
There's a mini MyTSN? Where? Which one?
Sow&Steady is offline
Old 11-03-2004 | 10:01 AM
  #18407
markp27's Avatar
Originally posted by Sow&Steady
Wow, really?!
I thought it was a lot older than that. I think there's too many old farts in here, err ... I mean MarkP and InitialD of course.
I would say it takes on to know one, but you're too old to be called an old fart - I think the term is decrepit
markp27 is offline
Old 11-03-2004 | 10:03 AM
  #18408
markp27's Avatar
99% of the 44.3% must be from D he never takes care about the content
markp27 is offline
Old 11-03-2004 | 10:31 AM
  #18409
markp27's Avatar
Nice anti-roll bar from Massimo Fantini:
markp27 is offline
Old 11-03-2004 | 10:32 AM
  #18410
Sow&Steady's Avatar
I agree with you ... it takes one to know one ... does that make you a decrepit then?
Old 11-03-2004 | 10:33 AM
  #18411
Sow&Steady's Avatar
Wait a minute, didn't I know a friend who didn't like blade type ARB for the rear?
  #18412
markp27's Avatar
Who, what, where - hey man I don't know who you are
markp27 is offline
Old 11-03-2004 | 10:34 AM
  #18413
markp27's Avatar
Ehm I'm too old to remember
markp27 is offline
Old 11-03-2004 | 10:35 AM
  #18414
Sow&Steady's Avatar
Yeah, I know that friend too. Anything he sees orange he'll like and forgets all the bad points about it before when it was in a different colour!
Old 11-03-2004 | 10:36 AM
  #18415
Sow&Steady's Avatar
Old 11-03-2004 | 10:41 AM
  #18416
markp27's Avatar
Ok, as your "friend" has a leaning for orange things, ask him where we can get one from
markp27 is offline
Old 11-03-2004 | 08:06 PM
  #18417
redsand's Avatar
Done installing the new servo saver and new diff clamp ring.
I have yet run the car, though due to weekdays activities. Please let me know what the new servo saver does to a car. From what I see it changes the ackermann angle quite a bit (more ackermann angle). What'd be the affect when running on a small track with lots of switchbacks (180 deg turns) ?
redsand is offline
Old 11-03-2004 | 09:11 PM
  #18418
InitialD's Avatar
I've also not tried it yet. Hoping the rain will go away.
I believe the new servo saver gives LESS Ackerman angle but you physically get more turning angle on each wheel. Julius mentioned that mid steering would improve on large sweeping tracks. I think someone mentioned here that it was good for him too on smaller tight tracks with 180 degree hairpins.
InitialD is offline
Old 11-04-2004 | 11:27 AM
  #18419
jag's Avatar
jag
What is the significance of the egg-shaped spacer on the front sway bar? I find that when I tighten that screw it will cause the suspension to bind.
Thanks,
Jim
jag is offline
Old 11-04-2004 | 11:35 AM
  #18420
markp27's Avatar
Thanks,
Jim
The egg-shaped spacer is an eccentric cam and allows you to correct the droop once you install the anti-roll bar. You should set the front droop without the front anti-roll bar installed. But once you have re-installed the anti-roll bar after setting the droop, you'll find a slight difference in the droop right and left. You use the cam to correct this back to what you set.
Cheers, Mark.
markp27 is offline
