Serpent 710
Old 10-17-2004 | 06:47 AM
  #17656
B4's Avatar
B4
Default Re: Re: Oversteer on power
Originally posted by Picard
B4
I ahd the same problem for the last month and it turned out to be the outdrive on the rear diff were worn, along with the rest of them, have you checked them?
Picard,
I have checked them and they are not worn.
B4 is offline
Old 10-17-2004 | 06:52 AM
  #17657
Picard's Avatar
Default Re: Re: Re: Oversteer on power
Originally posted by B4
Picard,
OK
Another question that got me
They actually wear on the inside of the outdrives and you cannot see the wear, stick a dogbone into the diff and see if you can turn it.
Another thing B4, when you car is on the starter box and you rev it does the rear jump up and down?
I know I am persisting, but this is the only rear end problem I have experinced with the car in 8 months
Picard is offline
Old 10-17-2004 | 06:54 AM
  #17658
InitialD's Avatar
Default Re: Oversteer on power
I'm running the following
front ball diff (medium)
Tighten this more. You'll find that it'll cure this oversteer problem. The car will be more stable. I believe Julius mentioned this before that with the front ball diff, it needs to be set very much tighter to get the car very stable.
InitialD is offline
Old 10-17-2004 | 06:55 AM
  #17659
markp27's Avatar
Default Clutch bell pics
pic 1
markp27 is offline
  #17660
markp27's Avatar
pic 2
markp27 is offline
Old 10-17-2004 | 06:56 AM
  #17661
markp27's Avatar
pic 3
markp27 is offline
Old 10-17-2004 | 06:57 AM
  #17662
markp27's Avatar
Hi All,
I have got my 710 handling fairly well but I'm having some difficulty with the following.
On exit from a slow or slow/medium corner i have to be careful with power delivery or the back end of the car will spin around. I'm running the following
yellow front springs
red rear springs
Rear diff set loose
Additional to what the other guys have said, make sure that you are getting drive to the front wheels, i.e. that the front diff is ok and the front pulley is connected ok.
markp27 is offline
Old 10-17-2004 | 06:59 AM
  #17663
InitialD's Avatar
Default Re: Re: Re: Anyone with a 710 kit which has a copper coloured 17T gear?
Originally posted by markp27
I'll post some pics. Yes, the kit has the black flywheel and I'm using the brass cone that came with the kit.
Perhaps the reason why it only had 0.5 mm A-B measurement is because the flywheel now sits more outward due to slightly smaller hole diameter that sits on the brass cone... Just guessing.
Are these clutch assemblies done on the same engine, Mark? Are is this a new engine you're fixing the clutch on? Not every engine is the same. Some may have more spacing than others.
Anyway, check to see how your stock old flywheel sits the same distance on the brass cone with the same shimming on the engine.
InitialD is offline
Old 10-17-2004 | 07:02 AM
  #17664
InitialD's Avatar
Default Re: Re: Re: Re: Oversteer on power
Actually, the rear of the car jumps up and down when it's really excited and raring to go on the track ! (j/k)
Yes, agree with you here. The dimples in the outdrives are difficult to see if you do not know where to look. These dimples "catches" the dogbones and prevents them from moving sideways int he outdrive upon suspension compression. When this happens, the rear suspension binds and makes the rear end hook !
And the rear end jumping up and down on the starter box when you gas the throttle is a sure sign that the outdrives are worned out.
InitialD is offline
Old 10-17-2004 | 07:04 AM
  #17665
markp27's Avatar
Default Re: Re: Re: Re: Anyone with a 710 kit which has a copper coloured 17T gear?
I was certainly wondering if it was due to the flywheel being painted-
I'll look into it.
I need to get my car finished off first, so I can tidy up or else GF won't like it
markp27 is offline
  #17666
InitialD's Avatar
Yeah somebody I know tried to drive the car with rear wheel drive only !
InitialD is offline
  #17667
Picard's Avatar
Mark
I noticed you are running the standard bell housing, any overheating problems with the bearings and the shoe's?
Picard is offline
Old 10-17-2004 | 07:05 AM
  #17668
markp27's Avatar
Yeah, I remember telling everyone about a *friend* of mine who had this problem
markp27 is offline
Old 10-17-2004 | 07:07 AM
  #17669
InitialD's Avatar
Default Re: Re: Re: Re: Re: Anyone with a 710 kit which has a copper coloured 17T gear?
Mark, you need to get the GF "acquainted" with the car and all that greasy hands...
InitialD is offline
Old 10-17-2004 | 07:08 AM
  #17670
markp27's Avatar
Mark
Interesting comment, Captain! On my current 710, I keep blowing the metal shielded bearings even though I have built the clutch as per Glenn's instructions.
When I was at the AMCC in the UK, I had Sow have a look at the clutch and he couldn't see what was wrong.
I use the yellow shoe with the standard spring. Clutch gap of about 0.6mm and 0.1mm endplay.
You believe this could be due to overheating?
markp27 is offline
