Serpent 710
Originally posted by Picard
I noticed you are running the standard bell housing, any overheating problems with the bearings and the shoe's?
I still have mine and use them occasionally without problems...
Originally posted by InitialD
Mark, you need to get the GF "acquainted" with the car and all that greasy hands...
Secondly - I'm afraid of getting her interested.....then there'd be no escape
Originally posted by markp27
When I was at the AMCC in the UK, I had Sow have a look at the clutch and he couldn't see what was wrong.
Well, so far no problems with them. I know a few who run the stock clutch bell with no problems either...
Interesting comment, Captain! On my current 710, I keep blowing the metal shielded bearings even though I have built the clutch as per Glenn's instructions.
I use the yellow shoe with the standard spring. Clutch gap of about 0.6mm and 0.1mm endplay.
You believe this could be due to overheating?
The endplay does not sound like alot either mark, How much movement does the bellhousing have when the clutch is assembled? I found also that if there is a fair bit of movement as the clutch engages and snaps onto the thrust bearing then this will also wear the bearings out faster in the clutch also.
That's true. You'd probably have to spend time wrenching, buying spares to replace broken ones more than you would have done yourself.
Well if not, just get her to get used to the idea that the RC stuff are part of the home's furniture.
If that fails, get a room where she can never access. Specifically RC stuff only. Learn from the professionals with experience.
The only thing I replace is the yellow shoe when it wears.
Is the colour of your clutchbell blueish black in colour? That's a sure sign of the metal overheating. Overheating would lead to the bearings failing and the clutch shoes melting.
You replace your clutch shoes? I never had to do that... Not yet. I'm guessing that the problems you have with your bearings and yoru clutch shoes is due to excessive clutch slip...
I think Mark mentioned that it was 0.1 mm end play.
Correct. More end play (not to be confused with clutch gap) means more "bang" the bearing will be subjected to. That is why the end play needs to be shimmed correctly so that only very little end play is resulted.
Sorry I though Mark meant he had a .1mm shim at endplay and that is all.
You are correct D .1mm is what I run and that should not create any problems. I aggree
I just got the ceramic thrust bearings, not that I have any problems with the standard one's at all, but again with sparksy I have no choice.Mark maybe try the new clutchbell, a few of us over hear run that bell because of the problems you described
You should know better than to trust both old pairs of eyes !
and that would be the least of my problems
but my gear has migrated into the lounge
She won't like that
I've still got a couple of hours
No the wear is due to excessive use, got about 5 months out of the shoe and then I replace them, no slip at all but understand what you are saying.
Regarding the old clutchbell, there are no signs of overheating and the clutch seems to engage quite snappily, i.e. no signs of slippage.
D
Got the new serpent tyres on the weekend and saw what you meant about the difference in track width
Had to turn those buckles right in but havent yet used them, used the speedminds, saving them for our next big event.
And BTW if they dont grip as well as the SM's at least they look fantastic
Ok, I'll try the new clutchbell.
Also, do you use grease on the thrust bearings and what condition is your spacer between the bearings in?
I hear what you're saying Bro - sneakily replace pot plants with a Tx unit, orniments with cars, paintings with pictures of the Prophets, etc
Oh, I'm already there
She won't like that
She won't like that
Looks like sparsky is somekind of Borg, isn't he?
