Rc10ntc3
#4516
Location: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
we should all make it up,save it,and paste it when needed..
#4517
yup, exactly ... anybody care to start?
#4518
Originally posted by fastharry
alot of guys that have todays PRO cars should have started like I did in '96..we used to run HPIs and kyoshos that all needed a grand in them to get around the track(even the racer2's 3 years ago).....and even with all that money in them,they were NOWHERE as fast as a stock tc3....
So i have no problem with replacing shoes,rebuilding ball diffs,or anything else the tc 3 needs..I've been racing 2 cars since they came out..and have less spent on both cars in a year(including the price of the cars)than I have in ONE HPI racer 2..
#4519
QUESTION
I wanted to know if the toe link is really 6-40 tread? If so, someone as find nuts to fit like Pavidis has done on his car?
#4520
Re: QUESTION
oh yeay,order some 3x3 set screws also..
#4521
Here's the link:
NTC3 tips link
-Puma
#4522
Originally posted by puma1824
I started to but then lost track of all the changes and updates.
Here's the link:
NTC3 tips link
-Puma
Here's the link:
NTC3 tips link
-Puma
#4523
front sway bar
is there a difference in the blade type sway bar?
I'm thinking about buying the team factory sway bar with the aluminum mounts, $50. But I also saw one from golden horizons, GH02420 which is $25.
#4524
puma, great page!
#4525
hows the Mugen?..
hows the Mugen?..
I may switch to a front diff because the track I run on is pretty short and having 1/2 the brakes make it diffcult to slow down in time. Which makes tigher corners? One-way or diff?
I have actually abused the car pretty bad and so far haven't had problems with the belts. I even used it in a pretty bad parking lot. I did get a few pebbles but I "think" I would of had the same problem with my NTC3 with the gears being chewed up in the parking lot I was running on.
I think I'll take out my NTC3 again just to see which one I like better. All time spent so far has been on the MTX-3 and I forgot what the NTC3 was like. I would need to change the servos in the NTC3 b/c I originally but cheapo ones in there and the MTX3 has the nicer MG and BB servos.
The MTX3 has actually made me a believer in foam tires. I used to burn up rubbers pretty fast in the NTC3. What do you use and like more, foam or rubber tires?
In general the MTX3 has been great accept for part support. This past weekend I banged 2 exhaust pretty bad. The first was during a race (Novarossi one-piece) the other a REX (Novarossi rebadged? Two-piece) screwing around in a parking lot and got a little heavy one the gas and slammed into a curb. Not one part broken just a banged up pipe.
So presently I'm torn between the 2 cars. Maybe I'll have a personaly verdict soon. Right now the NTC3 is better in parts availability,pebble free drive train, rubber or foam setup, a lot easier to work on (assuming I will have to take the MTX3 apart to replace the belt when it's time, and the clean receiver enclosure. MTX-3 (please don't scream) a "little" more durable, belt "may" better match my driving (maybe I should add some drag break on the NTC3), I like the gear diffs because I can pretty much set it and forget it. I would loose setting on my NTC3 (am I doing something wrong?) AND believe it or not I'm the ONLY one with a MTX3 at my track. Everyone is using a NTC3.
So again I'm torn....maybe I'll like the G4 or R40 better because of the top access belts.
-Puma
#4527
The Associated one way or the Yokomo one way. I would like to get the Yokomo piece as I hear is better quality. Has Associated improved their one way piece? I came in 2nd place in a 15 minute main and the reason is corner speed. This was with a bone stock TC3 except for springs. The car ahead of me...MTX3. It's beatable though. Stock clutch! No slip and I had motor!
#4528
Registered User
Hey Herb, How do you like the K-Factory fuel tank? Ain't it a bitch to pay that kinda of money for something that looks soo sweet , only to have it lean out big time when theres less than a 1/4 tank of fuel in the tank? I just changed over to the BMI chassis and some K- Factory goodies and all the AE Team parts. The tank is the only regret I have! I'm glad I only paid $30 for it instead of $50!! The BMI chassis is the best money I have ever spent on the car!!!! The chassis is a must for you guys!
#4530
I put two Orings up front for tues nite racing.....Just what I need..another fuel tank problem(along with my veteq)..
