GT class--buggy-based on road!
#6841
Glad to help
The part #s I gave you are from the 777 buggy, they are the "straight cut" gears you asked for and are more durable. (More expensive too)
The ones from the GT1 & GT2 are identical and are the "helical cut" gears.
All the GT's come stock with the helical cut gears from Kyosho.
We racers have adapted the 777 parts because most of the parts are interchangeable to the GT; remember the GT is really just basically a 7.5 buggy.
BD races are on Sundays not Saturdays.
But Saturdays is a good practice day
#6842
2011 Byron’s Fuels GT A Main
Position Driver Name Car # Laps Race Time Fast Lap Behind Qualifier #
1 Lyday, Mike 1 135 45:17.233 18.728 1
2 Sydor, Bill 6 131 45:13.445 19.317 6
3 Schutt, Eric 3 127 42:42.672 18.972 3
4 Lo, Howard 2 121 45:20.001 19.307 2
5 Borchert, Mark 5 119 45:20.356 18.827 5
6 Godbersen, Ryan 12 117 45:16.973 20.170 Bump
7 Barton, Pete 4 109 43:18.320 13.779 4
8 Gonzo 11 101 39:25.123 13.440 Bump
9 Vessall. Rick 7 86 34:36.513 19.565 7
10 Trac, David 9 45 20:23.730 20.416 9
11 Palansky, James 10 40 42:35.947 22.743 10
12 Cooper, Mike 8 18 6:01.799 20.041 8
http://www.liverc.com/view_result_fi...T_(A_Main).xml
#6844
nah ur right i got better luck with the straight gears than is101 is for the strr and it is diamond cut
#6845
Nice running with you guys
#6846
Here are the Byron's Fuels GT B Main results:
1 Gonzo 1 77 30:16.624 20.631 11
2 Godbersen, Ryan 3 77 30:17.062 16.594 0.438 13
3 Morales, Jose 4 75 30:14.307 20.377 14
4 Whiting, Foster 6 72 30:16.372 21.837 16
5 Echols, Ken 2 72 30:20.100 21.756 3.728 12
6 Rodney, Mark 8 69 27:41.215 20.860 18
7 Wernimont, Mark 7 69 30:03.208 20.865 141.993 17
8 Kiggins, James 10 48 30:31.434 14.964 20
9 Saulinskas, Jim 5 39 18:39.697 22.849 15
10 Stelmar, Mike 9 23 16:18.699 14.690 19
11 Rapacz, Greg 11 0 0.000 21
http://www.liverc.com/view_result_fi...T_(B_Main).xml
Congrats Gonzo & Ryan for finishing in 1st & 2nd places and catching the "bump" into the A Main!
#6848
yeah tell em to make more of the front modded shaft n ill do one up!!!
#6849
evolva 2-speed for a gt2 if there is an universal that fits
i asked this question on this forum before and i was told
is104....which is too short and does not fit the gt2 chassis
any ideas? even non kyosho that fit?
#6850
Another successful buggy conversion.
btw
Zo1gt mkII is half way done T.
#6851
Does anybody have basic setup sheets for the gt class buggy based road car?
#6852
the other question i have is, and tommy said you know, the (new type)
#6853
For those who like to be different ....here are pics of my Hot Bodies D8-based GT.
Front and rear clips are stock D8, center gear uses Kyosho GT1 modded uprights and top brace, stock GT1 shaft and drive cups, Evolva 1st/2nd spurs, shoes and 2nd gear holder, and the stock GT1 1st gear one way. The only mod to the shifter is to ream out the center hole of the 1st gear spur, and to drill and tap two additional 3mm holes in the one way to mount the first gear - very easy to do. No mods to the GT1 shaft is required. The car uses a GT2 100mm front dogbone, and a 95mm GT1 rear dogbone. The radio tray is stock GT1, and the tank is a 150cc D8T tank. The front and rear body mounts are GT1, and the front center post is from a Losi 8T. The front bumper, bumper mount and foam were fabbed by me.
The chassis was also fabbed by me, and is 5mm longer than the stock D8. I also kept the front flat - no kickup - which required me to make the top steering post mount as well. The chassis is genuine US-made 3.2mm 7075.
My design goals were to make a car that is strong and reliable, easy to work on, was slightly longer than stock but no where near GT2 length, used a straight center dogbone arrangement for a free rolling drivetrain, had the weight more rear end biased to help with traction and had no front kickup. So far I have been happy with the car on all those points. My original front bumper mounting was not properly designed, and I have to tweak a few hardware bits to get everything working properly - just typical new-car stuff. Since there were no D8 setups to refer to, and since I was new to onroad myself, I have been sorting out the setup details but the car is starting to work real well, and feels easy to drive. I have tried to get the stock D8 10/43 diff gearing to work, but I am giving up on that next because it is too hard to get the right ratios for the final drive. It could be done, but it will be easier to just run 13/43 diff gears, and standard kind of clutch/spur ratios.
I've really been enjoying the car, and the racing in the class. Dare to be different...
#6855
