GT class--buggy-based on road!
#6828
kyosho bevel gear?
does anyone know the parts number for the straight bevel gear set?
(ring an pinion?
(ring an pinion?
#6830
Easier said than done, when there is ZERO local - or even national or European part support for the DM-1 here.. The Kyosho parts are also a lot cheaper.. Plus the advantage of being able to use regular bearings...
I still don't totally understand why there is so little part support at places like amain and tower..
ps Is it even possible to run a 5-tooth split on the CB with the stock (4-tooth split) spur gears on the 2-speed?
#6831
maybe the company isn't doing so well? or the demand is so huge?
#6832
#6833
Dunno'.. Something must be up with Ofna though - no more Picco I hear, Jammin seems dead, etc..
#6834
#6835
You can shim it but its going to relocate your brake lever points,engine location and drive shaft (center) locations. Also depending on what gears you run you may need a fairly large shim.Just keep it in mind.
The thing I hated was drilling the chassis for the longer spread of the two speed (some cars you don't need to do this). I made an adapter plate for my new car I am working on.
#6836
Glad to help
The part #s I gave you are from the 777 buggy, they are the "straight cut" gears you asked for and are more durable. (More expensive too)
The ones from the GT1 & GT2 are identical and are the "helical cut" gears.
All the GT's come stock with the helical cut gears from Kyosho.
We racers have adapted the 777 parts because most of the parts are interchangeable to the GT; remember the GT is really just basically a 7.5 buggy.
BD races are on Sundays not Saturdays.
But Saturdays is a good practice day
#6837
Glad to help
#6838
Congrats to Mike Lyday on setting the TQ and winning big at the Byron's GT Class race!!
Ironman Mike does it again!!
Thanks Bro!
Thanks Bro!
#6839
#6840
Gratz mike....just got to know mike and im glad I did,,one cool guy..if anyone deserves to win its mike...I just hope that I can get enough info/help from him to someday I can give em a run for his money once again gratz mike cya next week killer
dnf don
dnf don
