GT class--buggy-based on road! >
Old 10-23-2010, 11:14 AM
  #4426
Trader Rating: 43 (100%+)
Default Looking for a GT.
If anybody is letting go of a decent GT class car I am looking. I'm partial to properly broken in force .28 but I am basically looking for a GTP,DM1 spec or regular,or inferno GT1 or 2 with a working 2 speed and life on the engine. Not worried about the body or electronics. Thanks inadvance.
crazysavage is offline
Old 10-24-2010, 08:21 AM
  #4427
mosaics12's Avatar
Originally Posted by arix
Hello Guys, I am looking for a good clutch and engine mounts for my Inferno gt since I swapped the engine with a Nova 21, I would like to know what aftermarket setups are out there that will work? I was thinking maybe the Losi 8ight 4 shoe clutch but not sure if the GT bell will fit in that clutch, also was thinking about the Fioroni Vario and the Ascendancy Effortless Clutch system.
If you have a decent setup for sale let me know.
i dont know if this fit
http://www.amainhobbies.com/product_...Mount-Extended
http://www.amainhobbies.com/product_...or-Mount-Black
mosaics12 is offline
Old 10-24-2010, 11:21 PM
  #4428
*1speedy's Avatar
Been running the King Headz 777 Quick change Engine mount for 2 seasons, its light fits perfect and easy
*1speedy is offline
Old 10-24-2010, 11:29 PM
  #4429
*1speedy's Avatar
Dynamite Max-Life Aluminum Clutch Shoe Set
This clutch last longer then any other 3 shoe set I have used to date (by far) and works great for me with 1.0 springs. Just be sure to knock the burs off after a race this will extend the life and function.
I have tried a few 4 shoe sets and the main difference to me was price.
Stick with the 3 shoe setup it works well.
*1speedy is offline
Old 10-25-2010, 05:33 AM
  #4430
Tabushi's Avatar
Other good alternative is to try carbon/composite shoes as the hotbodies D8 buggy stock ones, or ultimate ones ... they give you a nice grab/punch, low wear and longer bearings life ...
cya !
Tabushi is offline
Old 10-25-2010, 10:14 AM
  #4431
Thanks mosaics12, I went ahead and bought the Ascendancy Clutch from amain and got a set of MP9 mounts with spacers.
Should do the trick
arix is offline
Old 10-25-2010, 10:32 AM
  #4432
Should do the trick
The MP9 motor mounts lower the engine, did you get the MP9 flywheel? If not the stock size version may hang below the chassis.
williamw is offline
Old 10-25-2010, 01:59 PM
  #4433
mosaics12's Avatar
Should do the trick
let me know if that fits...they look d same height as well
they have this also
http://www.amainhobbies.com/product_...Mount-Standard
Old 10-25-2010, 04:09 PM
  #4434
Serpent-Dan's Avatar
Trader Rating: 18 (100%+)
At the local track Saturday with a friend putting his sedan through it's pace and was gonna do the same to his DM-1 but his crank shaft was bent so stripped the two speed gears. The other GTs at the track looked like they were on ice. Temp was about 64. The all had G_P tires(don't wanna say the name) but as got to telling one of the guys it was the tires. I told him of the way the Inpenema slicks worked and he had a set in his bag. His car was nite and day. Best tires made. He got off the stand all smiles
Serpent-Dan is offline
Old 10-25-2010, 05:34 PM
  #4435
llamont's Avatar
Default Body Options for IGT2...
Hello all
I recently picked up an Inferno GT2 and I was wondering what the body options were. Any info is appreciated.
llamont is offline
Old 10-25-2010, 06:29 PM
  #4436
Originally Posted by llamont
Hello all
Your choices are the Kyosho bodies, and the Warrior by Ipanema
Old 10-25-2010, 07:09 PM
  #4437
JLock's Avatar
Hello all
For the IGT2, you have 6 body choices:
Kyosho Corvette
Kyosho Audi
Kyosho McLaren
Kyosho Astin Martin
Ipanema Warrior
Alpha Audi R8
If you are going to race, the Ipanema Warrior or Kyosho Corvette would be the choices for big track racing. Can't really tell you much about the rest of the bodies because I never owned one of them for the GT2. As this class grows, there may be more bodies coming down the road. Until then, got to roll with what we have.
JLock is offline
Old 10-25-2010, 07:10 PM
  #4438
WildBillMassey's Avatar
Or the SC8 truck body...
WildBillMassey is offline
Old 10-25-2010, 07:53 PM
  #4439
Yes, I got the 32mm flywheel as well, this combo will give the car a lower Center of Gravity which is a plus.
arix is offline
Old 10-26-2010, 12:36 PM
  #4440
Livewire121's Avatar
Smile
Originally Posted by WildBillMassey
Those bodies are for the short wheelbase cars, like the GT1. I have an account with DeltaPlastik and can special order any of the bodies they make. Just email me if you are interested.
I was wondering if you can get any bodies for the DM-1 Pro 1/7?
Livewire121 is offline
