GT class--buggy-based on road!
#2312
Jeff,
Wish you the best with the organization of the event, i know for sure it require a hell of a work to lift a heavy event like this ... and im aware that you are working you butt off to give us drivers the first and best ever big GT Class event !!
cya !
Pato Concha
Southamerica
cya !
Pato Concha
Southamerica
#2313
Thanks guys.
The pull-starts don't have to be an issue, if the engine has it fine, if not it's OK for the "GT2-Spec" class too. So.... you don't have to use one.
Jlock, yes add the Sportwerks M26 to the list, it's cool, but it has to be "stock" inside OK.
The main thing with the spec class engines is that they have to be in the $200 or under range and they can't be mods.
The top 3 driver's engines will be "tech" with complete tear-downs to make sure they were stockers inside. So if you like to mod engines, better think of running the "GT1-Open" class.
Kyosho: GXR28SG
Kyosho: GXR28 (KYO74025)
Dynamite: .28 (DYN0890)
Dynamite: Mach 2 Monster .28 (DYN0992)
Ofna: .28 Force (OFN52217)
Axial: .28 RR (AX0330)
Axial: .28 Spec (AX001)
Axial: .28 Spec (AX002)
Ofna: Hyper .28 (OFN 53220)
LRP Z.28 Spec 3 (LRP32802)
Sportwerks M26
Picco P3
Now, in the GT Open class you can run whatever engine you want and way you want to.
Kyosho: GXR28SG
Sportwerks M26
Picco P3
Last edited by Jspeed; 09-02-2009 at 02:23 PM. Reason: Add engine list for GT2 - Spec Class
#2315
Jspeed,
Not to worry, my Sportwerks engine is bone-stock on the inside. I have had neither the cooling head or the pullstart assembly off of the engine. Thanks for the response about the engine. Got an Axial one off your list (had it for months, just too lazy to change it out) for my IGT2. But, I may dip and get a higher powered engine to run the IGT2 in the open class if I can make this race.
#2316
#2317
Jspeed,
#2318
Suspended
Jspeed,
Its good to see this much interest in the race. I will definetly be there man. Here is that video with the in car footage to get everybody fired up. More to come.
http://www.youtube.com/watch?v=9UtYeuTzfg4
#2319
Trader Rating: 26 (100%+)
Jspeed,
NICE VIDEO
#2320
Cool video Max!
#2322
Jspeed,
#2323
Suspended
OFNA DM1 Stand Up Shock Tower
Appreciate it guys. I with be throwing some more footage up as I edit it.
As far as standing the shocks up on the DM1.
There has been research done on the damping characteristics of shocks oriented horizontally compared to vertically. When you fill the shock there is always a bubble of air in the shock. It does not affect anything when the shock is oriented up right because the bubble naturally stays to the top of the shock and away from the shock plunger. The lay down configuration however exposes the shock plunger to the air bubble. This in turn makes the shocks damping inconsistant. As the air bubble gets mixed with your shock oil it is the same as using a lighter weight oil. Standing the shocks vertical makes the damping more consistant and eliminates an unwanted variable when tuning in your set up. Guys that drag race the DM1 would not see a huge difference with the standup orientation but if you are racing a curvy track its the way to go.
You can find the standup shock tower at www.maxvelocityracing.com
