Kyosho VoneR Thread
Whats the best 1st to 2nd gear ratio for the V-1-RR to ensure good gear change?
I am using 16/48 and 21/44. This gives me a 1st to 2nd gear ratio of 1.432. I think this is a bit high but have lost my 17t 1st gear!
Is there and ideal 1st to 2nd gear ratio?
Cheers
Cheers
Cheers
Cheers
THANKS DTM.
Anyone have some experience with options from 3 Racing?? Upper deck and alu parts in general?
And do the Kawahara chassie and low engine mount cause any problems with the belt on left side,?????
Kawahara Centax Clutch
I'm contemplating changing my so far reliable Kyosho clutch on my EVO for a Kawahara one.
Do any of you have experiences with this clutch or would recomend a different unit.
Thankyou
Thankyou
Re: Kawahara Centax Clutch
Thankyou
Thankyou
Re: Re: Kawahara Centax Clutch
Originally posted by vones
stick with the kyosho centax or you culd change the flywheel to the smaller flywheel for fw-05 cos the Kawahara centax shoes wears very fast.
I didn't know the Kawahara shoes are soft. Do you know if the FW-05 flywheel is smaller than the one from 3 Racing.
Re: Re: Re: Kawahara Centax Clutch
Originally posted by Manticore
the reason why SS clutch pad wears fast is because the fly weight is too light ! you need to make it heavier to reduce engage time.
I value your input and from memory reading this forum you are running swapping your motor/clutch between the MTX and EVO.
Is it better to replace the fly weights in the Kawahara clutch and if so, with what other brand. Or would you suggest maybe the Mugen clutch or even the Centax 3 from the recently released Serpent 710.
Hey B4! Same 2 cars as me! Evo and T1 NS 3 in the Evo and Novak Brushless in the T1
Re: Re: Re: Re: Kawahara Centax Clutch
Hi Manticore,
Hi Manticore,
there is no replacement for SS clutch flyweight.
the 710 centax 3 will only work on 710
on the ss clutch flyweight, there are 3 holes on each of the flyweight and you may insert grub screws up to 3 piece. this make your flyweight heavy already.
G4 has new ball diff. it should fit Vone series. but doubt about durability.
