Kyosho VoneR Thread
#5911
Whats the v1r silver edition is that the one wit the foam tyres or rubber?
#5912
NitroNut;
Originally posted by NitroNut
Doh!!! what kind of universals would u guys recommend?
#5913
Anyone have any info on the V-ONE RR GT NSX?
#5914
Re: tyre run time
Originally posted by RClover
juz wanna ask eveybody's view about the foam tyres run time on the track. well, i often play at parking lot (rough & dirty surface ones) where each time i put on a new set of tyre, the handling is juz great and am able to clock a faster lap time. As the rear foams wear out gradually to about 4-5mm thinkness remaining, the handling is very unpredictable and the rear tend to step out. I run 42 Front/ 40 Rear, and the run time is about 50min.
I am keen to know juz how long can a pair of Rear 40s last on a smooth track surface? (esp. like the track Manticore runs in HK).
i dont know if i have dont some wrong settings to the car or simply just the low quality of track surface...
How does the foam reacts (performance) when they are 4-5mm in thinkness on a smooth track surface? Low grip?
cheers...
cheers...
#5915
#5916
It is just a normal V1RR GT kit with the Kyosho NSX body replacing the Protoform Stratus body.
#5917
Originally posted by AMGRacer
Such as??
Such as??
#5918
Re: Re: tyre run time
Are the front and rears the same size at this point or are the rears smaller than the fronts?
But when four tyres are new, the car is grippy handles good. Is this the norm?
#5919
Re: Re: Re: tyre run time
the rear are smaller than the front tyres.
#5920
Re: Re: Re: Re: tyre run time
This is the much discussed over/underdrive effect. Basically strange things can happen to the handling when there is too large of a diameter gap between front and rear. I assume you have a gear diff in front?
yesterday when i ran the 42 front (5.5mm thinkness) and a 42 rear (4mm thickness). The car tend to understeer. i cnat figure out why...
those guys run on rubber tyres and are quick.
#5921
Does the kyosho universals #695015 work good?
#5922
Re: Re: Re: Re: Re: tyre run time
Nope, its a front one-way and a rear diff wif 100k.
Rubber tires dont wear un eavenly like foam
try changing your side belt and pully to a smaller one( I forget #s)
AMG probably does remember
#5923
#5924
Re: Re: Re: Re: Re: Re: tyre run time
If he's on the stock 27T pulley on the V1RR, changing to the 25T pulley will create more front overdrive.
If you mean changing the side pulley on the 2 speed shaft (stock is 19T), then yes it requires changing to a smaller pulley to keep the overdrive close to 1:1.
The answer to RClover's problem is a tire truer to keep the front and rear diameters the same or at a predetermined front and rear split. Alternatively, run fresh new tires front and rear all the time
#5925
why this reptile always step in while it doesnt know what people are talking about?
