Like Tree18Likes
Xray NT1
Old 04-27-2007 | 05:05 AM
  #691
rmdhawaii's Avatar
romuald31 ~ This is an interesting addition to your car....
rmdhawaii is offline
Old 04-27-2007 | 05:14 AM
  #692
Ice_nl's Avatar
Have you never seen that? a lot of drivers have that so they can rev the engine when the receiver and transmitter is turned of. with a screw it is easier to access when you want to test something like how the clutch engages.
Ice_nl is offline
  #693
itchy b's Avatar
Ah! looks like a throttle blipping handle! all good cars should have one!
itchy b is offline
Old 04-27-2007 | 05:28 AM
  #694
M7H's Avatar
M7H
on 1/10 sedan, yes..
on 1/8 lola, the holes in the body aren't big enough, to allow a finger...
M7H is offline
Old 04-27-2007 | 06:09 AM
  #695
rmdhawaii's Avatar
No, I have never noticed that on anyone's car before - not even at our track. And I don't think I've noticed it on any pro's car either - at least not in the pictures that I've seen. I went through the "gallery" threads real quick and didn't see it either!
Does anyone think this is a bad idea?
Old 04-27-2007 | 06:45 AM
  #696
bvoltz's Avatar
I don't know if it good or bad, but I hope you have a digital servo.... I prefer to twist on the arm connected to the servo
bvoltz is offline
Old 04-27-2007 | 06:54 AM
  #697
fastharry™'s Avatar
From: Louisville, KY!.. USA!! ....Home of http://www.fastharry.com
I prefer to hold the car,and blip the radio......that is the real test how everything is working......if you want to test the clutch,do you think you can duplicate the speed of the servo holding onto a screw?..(slower OR faster)
fastharry™ is offline
Old 04-27-2007 | 07:03 AM
  #698
Francis M.'s Avatar
Ive seen that on mostly sedans. Its a good idea to manually warm up your car before your qualifier so you can actually tune during warm up with a motor that is already up to temp. If you run a spectrum then I guess you can turn your radio on early with out issue.
Francis M. is offline
Old 04-27-2007 | 07:30 AM
  #699
supermoto552's Avatar
I see on the carb, there is an elastic band to presumably keep it closed, i.e throttle return, when servo's become detached?
I had this prob recently and was going to put a spring in to hold it shut, but that looks messy, is an elastic band ok to use, and what about heat?
supermoto552 is offline
Old 04-27-2007 | 07:42 AM
  #700
Pretty much everyone uses a rubber band for throttle return. It is actually part of tech inspection. The tracks I have been to for state races and such will not even let you on the track without one. The rubber bands used for braces (for your teeth) work really well. Just buy a bag full and replace it with a new one whenever you are servicing the engine.
Art Jensen is offline
Old 04-27-2007 | 07:53 AM
  #701
Artificial-I's Avatar
Dental bands or hair bands is what they are. I have a bunch in front of me. They also come inside of transformer toy boxes (dont ask). But ive been using these exclusively. In reality a spring thats strong enough to force a servo to move is going to wear on the servo and drain the batteries quicker. Ive been using the bands for awhile , cleaner and easier. Even though they probably wouldnt work if the servo is stuck at WOT.
But rest assured if the servo arm pops up , then your fine. Which even a throttle spring wont help. It has ample strength to pull back in that event.
Artificial-I is offline
Old 04-27-2007 | 08:23 AM
  #702
fastharry™'s Avatar
rubber bands won't cut it........
here's what you need.....
http://www.kyoshoamerica.com/techtips/throttle.asp
Racing regulations require a throttle return on all Nitro powered vehicles. It also just makes good sense to have some form of protection from a runaway in case of a mechanical or battery failure. Almost everything has been tried in the past to close the carburetor. From large bulky rubber bands to large bulky springs that look like they could close your garage door! Both work somewhat, but the rubber band is affected by the Nitro fuel and the springs just seem to be in the way.
The Team Solution:
Using these small thin bands solves all the problems and meets all racing regulations for a positive throttle return. Fuel does not affect these bands and they are so thin as to not interfere with anything in the area. Several cool colors are available. Check your local supermarket or drug store in the girls' hair dept for these type bands.
you're welcome..
Old 04-27-2007 | 09:07 AM
  #703
The Team Solution:
you're welcome..
Thats exactly what im using.
Old 04-27-2007 | 09:39 AM
  #704
fastharry™'s Avatar
yep..sorry I had to mention the name of another company,hope I don't get banned by the X Ray gods....
Old 04-27-2007 | 10:05 AM
  #705
Thanks very much guys, i'm off to get some right now, so simple, wish i'd though sooner.....instead i've got hurt toe and shin (well, luckily i was wearing motorbike boots) it was the trottle arm linkage that had vibrated loose, so no resistance on the carb, and the rubber boot pushing it open...screamed its brains out towards me in first, but caught it with my foot/shin, bloody hurt!! Thing is i've just replaced all internals in the engine apart from piston/cyl...so was just running it gently to bed the bearings in...huh, certainly done that now, just hope it ain't damaged it!
Cheers for the quick reply everyone.
