Xray NT1
#6046
I'm having this side belting problem that i don't know what is the cause......when i use composite pulley on both pulley(sideways) my belting ok but when i change to cso alloy pulley i'm losing the belting tooth...can someone advise how to solve this?...i'm using 25t.....is this the cause of my problem?
#6051
ya alum are not a must.. but the xray ones have holes in between the teeth to remove dirt dust ect... maybe thats ur prob? dirt is getting stuck and making it break.. i was picked up by rc america right before they released the pulleys and have built my car already.. i drilled 56 size hole in the plastic to create the same affect..
#6052
#6057
Nexus racing usually has most parts in stock, but at the moment I would contact your local Hobby shop and order some through RC America
. Well worth the 20 or so bucks. If your still a novice or race at a track with boards you may want to put them in the rear diff only if your worried about dnf's.
18Likes
