Like Tree11Likes
Xray NT1
Old 07-10-2018, 07:30 AM
  #7546
hi guys, just a question: what kind of thread locker do you use on this car?
I have a issue with the chassis and the front upper deck screws...i use blue loctite thread locker but the screws always pop off almost on every run. Maybe i'm doing something wrong? It never happened to lose all this screws on a single practice day than with this car...
Agro_pelo is offline
Old 07-11-2018, 04:18 AM
  #7547
Trader Rating: 47 (100%+)
I don't use much if any but always Loctite 243, it's the blue one.
I don't use any other brand when needed on anything.
Craig1 is offline
Old 07-17-2018, 10:47 AM
  #7548
Default .21 Engine on the NT1
has anyone successfully mounted a .21 on the NT1. and if so what did you do?
wrayth is offline
Old 07-21-2018, 07:07 AM
  #7549
NytroNutz's Avatar
I haven't done it on the NT1 but I have on other 1/10 cars here is what you need:
1. Enough room. Make sure your 21 will fit in the space first and not interfere with surrounding components
2. Adjustable engine mounts. This is a must since the mounting holes are wider apart on the .21 engine
3. Flywheel position Make sure the flywheel is centered on the opening in the chassis. Worse case you have to widen the opening.
I'm assuming you want to do this for drag racing, any other reason would not be worth the effort in my opinion. It would be too
overpowered for racing on a normal track. If you cant find a 21 to fit try a .15. When all else fails - search YouTube.
Hope this helps
NytroNutz is offline
Old 09-07-2018, 08:21 AM
  #7550
Logi Maker's Avatar
Trader Rating: 50 (100%+)
Looking for a '15 chassis and possible parts hoard...
jetnjme likes this.
Logi Maker is offline
Old 10-23-2018, 07:48 PM
  #7551
Default Engine mount
I know this channel is not a market or trade topic but I am looking for a NT1 monoblock engine block if anyone has one please reach out to me. Thanks
moisesing is offline
Old 12-07-2018, 11:45 PM
  #7552
Miami Racer 2's Avatar
Are parts interchangeable with newer models on the 2016 NT1?
Miami Racer 2 is offline
