Xray NT1
#3031
Just to let everyone knows....... Erwin Luhur with his NT1 , he qualified 1st in starting position, finished 1st place, and get TQ, in recent Futaba OS Speed Jakarta Cup 2008. Awesome right ? a triple one achievement
I'm sure there will be official news from xray sometime next month.
Here is the A main finalist :
Erwin Luhur, Xray NT1
Teddy Syach, Serpent 720
Arya Ridho ( 9 years old ), Serpent 720
Usman Halim, Xray NT1
Fayakhun Andriadi, Kyosho RRR EVO
Linardi, Xray NT1
Kris Heriyana, Kyosho RRR EVO
Danny Iswahyudi**, Xray NT1
Agung Dorojatun**, Kyosho RRR EVO
Sadikin**, Xray NT1
http://www.mylaps.com/results/newResults.jsp?id=808686
** DNF
Linardi, Xray NT1
Sadikin**, Xray NT1
** DNF
#3032
Trader Rating: 26 (100%+)
it's nice to see the nt1 on top but the 9yr. old wooooow
THAT'S GREAT keep up the good work kid
#3033
9 Yr. old , have chance world Champion
#3034
What's your front droop setting? I set mine to 0 but when the traction came up the car had a lot of understeer. Setting the front to 1 helped with this quite a bit.
#3036
#3038
#3039
...anyway what are you doing hanging around the NT1 thread...don't you have an engine to re build?
...or are you secretly still in love with the NT1 and wanting to get one? Master Arnamwat has one, when will you defect?
also, i've got some Tornado 16% that i brought in (finally got it from customs!) and Jay bought some of me. Preliminary results say it's pritty bloody good. PM me for more info
#3040
Was running at the track today and experimenting with changing the rear setup to overcome oversteering (rear breaking loose when turning in off throttle). I noticed changing the diff oil seems to be the most effective way than changing roll center. Is this correct?
Seperately, my front understeers a bit so I use a lower shore on front than rear which slows me down in turns. Other than changing to a 26T pulley (I am using 25T), what other things can I do without changing caster (I use max caster to get solid stability at straights).
I use 2 holes w 60wt oil front, and 3 holes w 60wt oil back. Pink springs.
Cheers.
Cheers.
#3041
Cheers.
Cheers.
#3042
Also how does the coning on you rear tires look?
#3043
XRAY NT1 New low price option parts
7075 T6 Alum. Hard Coated Pinion Gear (15-23T)
Alum. wheel Hub
Alum. wheel Hub
#3044
#3045
i don't think it's from Xray, maybe aftermarket options.
