Xray NT1
#3046
Thanks for your suggestions D-nicest.
Sometimes I just loose my patience especially when I see some of the guys are running their car so so well....
My rear tires wear evenly actually which makes me think my rear camber is good. However my front wears more in the inside I just checked so I will try less camber up front.
Will try more rear droop first next time. THANKS
#3047
reduce the rear droop so the car does not lift as much (ie go to a more + number on your hudy blocks), and increase the front dropp so the front lifts more on corner exit. (ie go to a more - number on your hudy blocks on the front)
#3048
Post your full setup online here, so we can take a look. Its hard to give correct advice without the full picture.
Droop is probably not the answer though.
#3049
mate if your rear end slides out on entry off throttle more rear droop (ie lift) will make it worse.
#3050
#3051
If your rear tires are wearing evenly, then you probably need to increase the rear negative camber and/or toe-in. The rear tires should definitely cone to the inside at least with a sustained 0.5mm difference between the inside and outside diameters.
http://forum.teamxray.com/xform/inde...=639&setup=nt1
#3052
Suspended
Thanks for your help. I uploaded my setup here.
#3053
* Change rear downstop to 5, for less weight trasfer to the front on entry
* Increase rear toe-in to 3.0d, to stabilize the rear more
* Increase rear camber to 3.5d, to give more side bite to the rear
* Increase caster where you have 1.5 shims on each side of upper front arms, to decrease entry steering and increase exit steering
* With the one-way, I'd recommend reducing the ackerman by flipping around the A/D block so the inner links are all the way forward. The setting you have now is better for a spool.
* Move inner rear camber link position down to #2 and increase outer camber link shim to 2mm, to increase camber gain and give more side bite to the rear
#3054
GK's suggestion is a good one. Here are the options I'd recommend trying (one at a time and in order):
AND NEVER EVER CUT REAR TIRES TO BE USE AS FRONT TIRES.
Bboy : ( perhaps this is my personal setup, you don't have to follow )
Recently I've been using softer tires for front and harder tires for rear with 2.5 mm split. I use Kawahara 37 front and 40 rear. Why harder rear tires ?
1st. This help reduce excessive rear tire wear in my car. After 1 hour practice, front tires and rear tires end up almost the same diameter. Sometimes rear tires still get 1mm bigger in diameter than front tires. ( fyi : driving with smaller rear tires than front is really lousy to drive ).
2nd. I need more steering + higher cornering speed. Softer tires at front in theory will create more front bite, thus creating more steering and possibly higher cornering speed too.
3rd. I'm still using front gear diff. I don't use one way. Using front & rear gear diff setup require 1:1 overdrive ratio, otherwise you are either dragging front or rear tires. Harder rear tires help me to maintain close to 1:1 overdrive ratio during long final because front and rear tires are wearing at the same rate.
#3055
Cool guys. Let me try them this weekend.
Can't wait for the weekend......
#3058
You'll end up with 5.5% front overdrive, which should provide a slight increase in on-power steering over the 25/18 combination. The front tires will also wear more.
#3059
Suspended
#3060
