Kyosho V-ONE RRR Evo
#2446
Ric B
#2448
Hi John, Ric here, I have lowered my fuel tank and do so on all my cars where there is room to do so. It requires different screws, longer of course, and I use plastic shims and o rings to lower it. Depending on how much room I have, I change the number of O rings.
Ric B
Ric B
#2449
Has anyone tried the Sirio power clutch on their car. If so, could you tell a performance difference on the bottom end?
#2452
Thanks for the speedy response. Where is the best place to order one from? For a good price.
#2453
similiar on clutch set up & way more rip in the infield a little to much so I cranked it down some more to gain more bottom end for the straightaway since it is a long straightaway comparing it to the 4D it has the same aggressive feel on shift point but is way smoother & spools up way quicker so you will need to adjust your shiftpoint I just measured the spring tension I started out @ .60 & adjusted it to 1.1 will be testing it out on a smaller track this weekend
#2456
george you go to bed.
#2458
#2459
