Kyosho V-ONE RRR Evo
#1696
PM
nikiskar you got PM
#1697
Originally Posted by nikoskar
Thanks a lot Martinez.I Bought the Sirio but i see both of the engines and i think that the CRF if faster.Maybe i have bad settings.
Thanks Again.
Regards,
Nick
Thanks Again.
Regards,
Nick
Sirio it's in the clutch & Im basing the info from a top driver who ran sirio & now is running the CRF & I asked him the same ? & Im replying to what he stated. Tell me your gearing & clutch set up for the sirio & the track dimensions so I cam give you some pointers & most important are you using the 3D or 2D
#1698
V1RRR/FW05 Alum. Lower Spring Cup (4)
Would this fit the EVO WCE shocks?
KFactory V1RRR/FW05 Alum. Lower Spring Cup (4)
Item No. K1920B (Blue)
#1699
Originally Posted by GMartinez
With the CRF the gearing has to be right on the money
I have the following.
I don't know the exact track dimension.But is tight.
I use 3D Clutch with 1.2 Spring and 0.5 mm Clutch Gap.I have the default gearing. Other local top racers with this motor are using the same gearing if we have the long straight or using i teeth below if it is shorter.
I already bought the 2D Clutch.I think this motor has better perfomance with the 2D Clutch.The spring should i put it 0.2mm?
Best Regards,
Nick
#1700
what tools for flywheel uninstall and install are you using?
there are many options
all from rc-mushroom site
JP Flywheel Universal JP Key [JP-93863] http://rc-mushroom.com/product_info....ducts_id=10409
QWorld Flywheel Wrench [QW-LC-2616] http://rc-mushroom.com/product_info....oducts_id=1087
JP Racing Flywheel Exctractor [JP-93861] http://rc-mushroom.com/product_info....oducts_id=9454
Kyosho EV05 Flywheel Puller [KY-80162] http://rc-mushroom.com/product_info....oducts_id=7117
SH Flywheel Remove Tool/Brown [SH-SS330A09] http://rc-mushroom.com/product_info....oducts_id=7025
JP seems to be the most durable and best quality, but I don't know if the Universal Key and Exctractor will fit on RRR and Evolva flywheel, also the Exctractor has a metal tip, it got no protection like Kyosho tool, thats worry me, because it can damage crankshaft and unusable it, or am I wrong? The SH its the same thing
Qworld is the cheapest. Looking at the photos seems to be bad quality, never saw somebody using
#1701
#1702
#1704
These are what I am using and they work just fine.
http://cgi.ebay.com/Mugen-MTX-4-Alum...QQcmdZViewItem
The ones you listed are going to be too large a diameter for the EVO springs.
Eric
#1705
Getting my spares soon, can't wait to get back to the track and test! Took a look at the car and saw that my Kfactory ventilated disk was backwards, this could have been the cause of the 2nd gear spur gone in few laps? Hmm, I haven't seen anything else wrong w/ the car. Will update after a test run.
havy
havy
#1706
Thanks a lot Martinez for your help.
Best Regards,
Nick
Best Regards,
Nick
Most of the time I set up the spring tension to .8 & endplay of .3 for big tracks on the 3D it depends on the motor & .5 spring tension & .3 endplay
for the 2D here is pic of the track & it has a nice long straightaway
#1707
Martinez,
You also have a very good track which you can check different lines.
#1708
Hey all evo guys I am in the process of thinking of buying a evo, but I am asking because I currently have a rrr wce but wondering if the evo wce is worth buying is there a difference or should I stick with my rrr wc, be honest on what you think..
#1709
Well, well, well.............. I just heard somebody say "i'm sticking with what I have". What changed from an hour and a half ago?
I don't know if it is worth buying the evo over the wc but is it a nice car! You wouldn't be disappointed. It has cool hop ups..!!!
Later!
Buy it, you know you what it
Later!
#1710
Later!
Later!
