Serpent 720
Old 08-30-2007 | 05:37 AM
  #2866
Julius's Avatar
Originally Posted by typer
Julius, what steering blocks do you recommend here at jp racetracks in manila? 0 or 1 mm offset?
When I was at JP last time I used the 0degree ones. They reduce the traction roll.
One thing I haven't tested there yet is using th 1 degree blocks but left and right side reversed. You'll get more steering in the middle of the corner without adding traction rolln tendency at corner entry.
The 0 degree blocks are definately the safer choice.
Julius is offline
Old 08-30-2007 | 05:39 AM
  #2867
Group buy anyone
http://cgi.ebay.com/SERPENT-Parts-Ov...QQcmdZViewItem
implusepro is offline
Old 08-30-2007 | 08:49 AM
  #2868
typer's Avatar
Smile
Thanks bro...race with us again..
typer is offline
Old 08-30-2007 | 08:51 AM
  #2869
typer's Avatar
Originally Posted by Jo Gutierrez
The pressure chamber provides an extra room for consistent pressure from full to empty tank.
Ok...thanks bro
typer is offline
Old 08-30-2007 | 07:02 PM
  #2870
RevMaxx's Avatar
Originally Posted by buboy28
RevMaxx: that thicker ring you are mentioning, is that also a Serpent item if so what is the part number and what store did you got it from, thanks
not sure if its a serpent part as it came separate. the shop owner handed me the 3rd one-way kit and just taped the thicker ring with the pack. i'll try to inquire if i get the chance to visit the shop again.
got it at Harmony Models at HK... see pics
RevMaxx is offline
Old 08-30-2007 | 07:06 PM
  #2871
roadrage's Avatar
do the new knuckles give you more steering?
roadrage is offline
Old 08-31-2007 | 08:03 AM
  #2872
1FastSerpent's Avatar
When I Talked to Gianni , he was running the 0's & I believe he said they are the same as the Stock knuckles & the +1's added steering. Or it was Vise Versa. But yea, one of them adds to the steering.
1FastSerpent is offline
Old 08-31-2007 | 08:19 AM
  #2873
MNF1SAND's Avatar
The first generation had the second ring that needed to replace the original. The product that came out after that already had the new ring in the package. There is no part number for the ring alone.
MNF1SAND is offline
Old 08-31-2007 | 02:30 PM
  #2874
roadrage's Avatar
thanks mark. i have both i guess im just gonig to have to test! are you going to superior?
roadrage is offline
Old 08-31-2007 | 07:39 PM
  #2875
Austin, Fingers crossed I can make it over. I had a blast there last time. And Now that I got the front Diff figured out in the car , It should be real good.
Old 09-03-2007 | 05:54 AM
  #2876
typer's Avatar
What is the problem with the ring that came with the set? I got mine recently and it fits ok.
typer is offline
Old 09-03-2007 | 09:32 AM
  #2877
RevMaxx's Avatar
i believe the 3rd one-way set that i got were of the first batch which had a thinner ring. the succeeding batches came with the thicker ones, as MNF1SAND mentioned...
RevMaxx is offline
Old 09-03-2007 | 02:50 PM
  #2878
0 is less stering 1 deg is more stering .
maxy is offline
Old 09-03-2007 | 06:32 PM
  #2879
roadrage's Avatar
i used the new 1 deg knuckles yesterday on a tight set-up track. I had real good steering. TQ and 1st
roadrage is offline
Old 09-04-2007 | 01:57 AM
  #2880
typer's Avatar
Have you tested the 3rd one way? I havent tested mine yet.. busy lately
typer is offline
